2014 6L80 question
Charlie207
LFOD, New Hampshire
@BlackBearPerf
Hi, is it possible to program the engine/transmission to keep the torque converter fully locked when the transmission shifter is in Manual Mode? (maybe not in 1st or 2nd gear... IDK)
I'm running into some scenarios where I'm coasting to the bottom of a long steep hill with a Yield sign at the bottom, and the transmission wants to shift into 6th (top) gear as I slow down, but spends at least a second hunting for the correct gear to be in as soon as I see the intersection is clear and hit the gas pedal. The engine revs, but since it's hunting/pecking around for 2nd or 3rd gear I have a lag, then jolt as it engages with the RPMs higher than normal.
I've had your 93 octane 5.3 tune for a couple years and have been happy with it, but I'm finding the exception to the rule in this scenario. Thanks for your thoughts.
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
Unfortunately not. The "M" mode shares all shift patterns with your normal mode and really isn't a "manual" mode, it is a "maximum" mode, shifting up and down all necessary gears, but limited to the maximum gear indicated. If you would like to send in a log file showing that specific scenario, there may be other adjustments that we can make.
Charlie207
Charlie207
LFOD, New Hampshire
Thanks for the reply. I can try to log some data this weekend. It's been a while since I've done that, and is there a way for me to note (via the AutoCal screen?) a timestamp to refer to?
BlackBearPerf
You are welcome. If you have the AutoCal V3, the timestamp displayed once you transfer it to your computer should be accurate. If you have the older AutoCal, the timestamp will be off.
@BlackBearPerf
why not just use the tow haul button? that keeps it in whatever gear you finnagle it into and then as soon as you hit the pedal it goes up, works great for me. saves the brake pads too
jpurdie
