Power running board fix discovered
rbg1957
I've got a 2018 yukon denali.xl with power running boards. I bought it used last year, and didn't realize that I could've continued to look for one without them. Living in WI, I figured they'd give me trouble with the winter weather. Sure enough, for the last 3 months the passenger side board mostly stayed extended, even when I sprayed the gunk out of the hinges. It would clunk multiple times, but not retract consistently.
I asked the dealer and my body shop, and both wanted to replace the motor for about 1k, I think.
Today I was at menards and grabbed some 3-1 garage door lube. I had just washed the truck yesterday at the manual car wash, so the hinges were clean. I gave them a good spray of the garage door lube, and within minutes, it started working exactly as it should. It irritates the hell out of me that the dealer was just going to make me waste a thousand bucks for something this simple!
CMoore711
Thanks for posting this and what solved your issue.
The power retractable running boards are definitely a love hate thing. IMO they look so much better than the standard fixed running boards when they're retracted and not in use. Additionally, I find them to be significantly more functional when they are extended and you need them because they're positioned slightly farther away from the vehicle (when extended) than the fixed running boards. Because of this I find it easier to actually have more solid footing when standing on them getting kids and gear in/out of the vehicle.
Just like any other moving part they do need to be cleaned and maintained if you want them to stay functioning. You've done the best two things you can do; Keep the hinges clean and free of debris and build up the best you can and lubricate the hinges. I'd recommend keeping them lubricated as routine maintenance, and more often in the winter months.
Welcome to the Forum from NH.
Pics of the truck, please.
Thank you for posting your solution to your issue. Our collective knowledge base has been increased.
B-train
Welcome from a fellow WI guy. Thanks for sharing!
R
rbg1957
Thanks for reading my post. I want to mention I did try wd 40, and even penetrating oil before. Neither did a thing. It's only because I needed the garage door lube for my overhead doors in my polebarn that I bought it, and a lightbulb went on. If you think about it, the garage door track lube is working on a very similar mechanism and needs to stay where you put it to be effective. I'm not saying I'll never need a new motor, but if this helps get another year or 2 out of them, that'll be well worth it.
Tonyv__
Bucks county PA
Irritating as hell on the dealer part but that’s the name of the game. They won’t try to service something that isn’t serviceable with the worry of you coming back and telling them it didn’t work and that they need to fix it! Replacement almost guarantees you won’t be revisiting that problem again for a long time.
With that being said, I’m gonna look into the garage door grease, my passenger side isn’t sticking yet but definitely doesn’t sound as smooth as it should.
Eups_73
FYI make sure you use dry lubricant. I figured that out after using regular WD40 and still having problems. I learned this after going on AMP running boards website and that's what they recommend.
91RS
GA
Correct, a dealer (or any shop) can’t guarantee that “repair.” If they did that and charged you, once it starts acting up again in a week, you’d be back in there shouting that they ripped you off. The customers have made it this way. No one can try and help the customer out because when it doesn’t work out, the customer still thinks they’ve been ripped off. So, if they're going to think they got ripped off regardless of what is done, at least do the repair that will keep them from coming back.
arkie
Dealer turned me onto Kroil penetrating oil.
Haven’t had any more trouble with regular use.
petethepug
Michael
SoCal
Makes me want to duct tape a can of Kroil to the underside of my truck and take it in for the p/s that’s not working.
I’ll leave a note in plastic bag that says $1000 fix. Pls spray on hinges liberally.
NothEastTahoe
I had those things on a truck a while back, I am in MA so not as much snow, but in the hills we still get plenty. I hated them, instant regret and remorse in buying them after the first snow. I will never own a pair again. The oil fix is good to know, but there is no fix for the snow and ice jamming into them and freezing.
You can tell certain cars/products are invented by people who never have felt the cold in their life. We had a telluride before this and the windshield wipers sit below the hood and you literally can't clear the snow out of them in the morning.
Cali designer life I guess!
RoadTrip
FL & MN
This is truth! How about recessed door handles and flush fit door edges that fill with freezing rain, assuring that yours doors are sealed shut?
I used see videos of “test teams” from manufacturers with their vehicles in Duluth, learning how winter weather changes how a vehicle operates and drives.
Cost cutting shut down the R&D apparently.
fr8bil
Table Rock Lake
Great product for sure but I discovered similar results and performance to Kroil with less expensive FREE ALL penetrating oil. Of all the crazy places, I learned about this product from a good old boy at the local trailer repair shop when my utility trailer's, foldable, rear drive-on gate's hinges froze up and this product fixed them in 3 minutes.
BacDoc
Vero Beach Florida
Nothing like the “good old boy” at local trailer shop. I use a local trailer/welding shop that has been in business for over 40yrs, family run, country boy can survive, quality hard work and fair price that pays off for everyone involved. The American work ethic that built this great country still exists! Let’s support these guys!
dkman610
Minneapolis, MN
Hi where exactly did you spray? I have the same issue now
adventurenali92
Big Bear Lake, ca
It’s funny that your first comment about the power running boards is that it’s a love/hate feature….. I’d agree in that theres no middle ground.
As a detailer I absolutely hate them and I will never have them on a vehicle I personally own. I absolutely hate that on the GMT900s that have them, the disable feature keeps them retracted up against the bottoms of the doors. What knucklehead designer thought that was the way to go with the disable feature?!?! I always need them dropped to properly get them cleaned up, especially during the winter months when the actual step part is covered in mud and all the crap leftover from the snow, but then that means leaving doors cracked open slightly during my power wash step to keep them extended and of course that means extra moisture in the door jambs which annoys the heck out of me. Plus….. every time I open or close a door they go up and down and I’ve had WAY too many clients cars jsut randomly go dead battery and I can’t imagine that the running boards going up and down every time is good for the electrical system when the vehicle isn’t running while I’m working on it.
I also don’t like that they are flush with the bottoms of the doors. So many vehicles I detail all the time with no running boards or with power boards, the paint at the bottoms of the doors is always thrashed from road debris and crap constantly being flung all over them. The bottom sections of the doors always have this really ugly whitish, very rough to the touch stretch of paint and it sucks cuz it makes the car look so much older and more used and abused than it is. And of course my eyes go right to that spot cuz I can’t not see that detail…. lol I mean not that the bottoms of my doors don’t see road crap cuz they do but they don’t get that thrashing to the finish because my fixed running boards keep enough of that off of them.
Then there’s the newer rigs. I like that they have a setting that keeps them deployed for when I’m detailing them. Great feature…. And perfect so I don’t have to worry about killing the battery every time they move. But why in heavens name on the T1 platform rigs does the vehicle have to be RUNNING in order to access this feature?! I hate getting setup and then having to start the clients vehicle and sit there and scroll several settings menus on the infotainment screen just to get to it and keep them deployed? Again what knucklehead designer thought that was the way to go with this feature?! Why did they do away with the button on the dash panel that will deploy the boards with the truck in accessory power like the K2 platform?!
And then there’s the issue lately I’ve been seeing all the time with latest gen rigs that even in deploy mode they will just randomly go up and down cuz they have a mind of their own….. and the weird part is that it’s not just GM that’s got the issue. My long time client with a 2020 navigator L black label package has been having the same problem with her running boards for almost a year now. Two different ram trucks I detail for regular clients with power boards are doing it. My landlord(a husband and wife couple I’ve known forever) are big on GM and her 2021 Denali has started up with the same issue in the last few months. I was detailing it for her this past week and while I was standing on the passenger side board at the front door, drying off the roof after the wash, with them in deploy mode, the board retracted and the fact that my weight was fully on it did not stop the board from retracting. It smashed my feet into the bottom of the rocker panel so hard it bruised the tops of both my feet….. yeah that really irritated me lol. And then an hour later I’m working on the drivers side steam cleaning the dash and steering column, sitting on the drivers seat with my feet hanging out over the board and just lightly resting on the board and the drivers side went up on me…. I had to push my foot down onto the board really hard so that it would stop and not crush my foot again. Like what is going on with these things and why are they ALL not functioning properly and so badly not working right…..
End rant….. lol needless to say I despise the things and I’ll be in the market for a 900 soon, either a Denali XL or an esky ESV, and if whatever I buy has power folding boards swapping them out for static boards will absolutely be priority one mod the minute I get my hands on said truck…. Hahahah
91RS
GA
You just open the door to extend them and step on them after you close it and they stay extended. Open and close door again to resume normal function. It isn’t that big of a deal.
dkman610
Minneapolis, MN
I wish that's all it took, the other day my 10 and 11 year old opened the door to get in and they retracted, so needless to say I need to do better at working/fixing/maintaining based on this thread. I bought a case of that 3-1 garage door grease (some for the garage door, some for the running boards.) LOL
dkman610
Minneapolis, MN
I live in Minnesota and yes I struggled in the winters, but we're not dealing with snow so far this Autumn and they've been acting as if I've been driving through snow. I'm hoping to get this 3-1 dry lubricant into the hinges/jambs/etc. to see if they behave differently/normally. Honestly, I didn't think a leaf stem would cause so much trouble, which I seem to think/see this as the issue at the moment.
johnsonwillie199
