Power running boards
Upholsteryman
2015 Yukon Denali power board stays out. When I shut door it tries to go in but only about 1/2” then goes back out. Acts like it thinks door is open.
wjburken
Eastern Iowa
Very likely you have a hinge assembly binding and the motor is hitting its torque limit. This can be caused by dirt and grit building up in the pivot points.
U
Upholsteryman
I sprayed silicone wd 40 on all moving parts. Can I disassemble them and clean them?
U
Upholsteryman
OK now that everything is lubed up I can push it in with my hands and it’ll stay in but when I open the door it opens back up when I shut the door. It won’t go back in like it’s hung up but I can help it with my hands every time and was trying to keep doing it to see if it would eventually work correctly. Do you think it could be a motor?
wjburken
Eastern Iowa
Yeah-these retractable running boards can be a pain. The motor controller has a torque limit setting and if it sees more than that, it just says “F-it, I’m not gonna do anything.”
It’s for this reason I have given up trying to get them working on our 2013. Iowa winter roads just mess them all up. If I find a decent set of fixed running boards, I’m swapping them out.
BadDaddy2003
