OBS Escalade...HID WOES
hassoun
Germantown, MD
they should fit fine. they are just a ***** to get them in all the way. it should go in fine but will take u a while to twist it so it locks in place
roadrageror
ROADRAGEROR
alberta,canada
well i have a new fog light housing that has not yet been installed so maybe ill try to put the bulb in that one while its out and i have lots of acess.might have to take the other one off if its easy. ill post up when its done(hope it gets done) lol
roadrageror
ROADRAGEROR
alberta,canada
well i was trying to get the bulb in the foglight..the bulbs seem to be just a bit too long to fit in the and the wire beside the bulb that is coated white cracked and a little chunk broke out of it. does anybody know if this will ruin the bulb? cant be good for it.i have the housing in my living room and was careful but this is ******!
foreverfalcon40
foreverfalcon40
I orded mine 4,3K Hyper white...gonna hold off on re-doing the Headlights due to my projector project!
STILL NEED THE WIRING DIAMGRAm!
destroyer1362
A work in progress
Midlothian, TX
I did the same thing, cracked, the bulb still works. Looks like the dremel will be a necessity if were going to get these to work..
foreverfalcon40
foreverfalcon40
Well get some pics up then. Few car show comin up u going to any?
Baldhill?
Might take a Sunday off and hang all day. Last time I went suppose to get a few trophies but I couldn't stay all day so therefore I didn't qualify.
It was also one other DD SUV there :)
roadrageror
ROADRAGEROR
alberta,canada
well i started a new thread (880 fog light install questions?) but anyway what im going to do..and did to one side already was take it off the truck so i can handle it better(2 bolts) but i just put a bead of hot glue gun around the hole on the fog light.pushed the light into the hole as far as it wanted to go in which is all the way except for the "twist and click" and then put another bead around and then wrapped it up with black tape to seal it up tight. so later tonight i will put it on the truck and do the other side..(i think im gonna order spare bulbs tho)..i dont want to dremmel it out so this is the route im going...hope to post a pic of the finished later!!! fingers crossed.
nytahoe
"Tha Butcha"
new york
sat nights in simthtown stop and shop cruse nights think a show this sunday might go after work
foreverfalcon40
foreverfalcon40
You got my number but I have work till late. Maybe I can get two other Hoe guys out here.
What time does it start and end?
---------- Post added at 12:37 PM ---------- Previous post was at 12:35 PM ----------
P.S. I ordered my HIDS from DDM last night. 35 watt 45k. I want the brightest as possible.
I'll take pics of the install of the bulb if needed.
I plan on dropping off the truck to have the wiring done b/c I have no idea how to make it work with the OEM Fog Light Switch.
foreverfalcon40
foreverfalcon40
Why no dremel...just asking out of curiousity? Stick out that bad?
roadrageror
ROADRAGEROR
alberta,canada
just the way i wanna do it. the whole inside is reflective and i dont want to mess it up..im pretty sure it would work but im pretty happy just using the glue gun. the light sits pretty flush just wont turn and lock into place.i also did it this way cause i already had one done that way when i wrote that post.lol. but i guess time will tell as i use it for a while in the elements..but i am going to order 2 brand new fog lights for next year because mine are old and not the clearest,one light is brighter than the other because one looks more faded than the other. here is a pic!
briannorris
