Intellibeam operation
JCSFPD
2024 Yukon XL SLT equipped with Intellibeam high beams. I have read the owners manual. 25mph and above, headlight switch on automatic, dark outside. I have pushed the turn signal stalk forward twice in less than two seconds. I am not seeing a change in the high beam icon on the instrument panel. Any ideas on what I am doing wrong?
Chad G 1979
The high beam icon will turn off as you had double selected it. There should be another icon that is green that shows the high bean icon with an A on it indicating that auto high beams are now selected. Once that is done, your high means will automatically turn on and off as the vehicle decides when its dark outside.
I dont use it as i find even in town with lots of lighting that they turn on and off a lot. In town i can see quite well and pretty far so dont know why it thinks i need the high beams. That is personal preference though on that.
John52269
If you have a Yukon and use your fog lights, it will disable auto high beams.
Chad G 1979
Ahh, that is something i hadnt considered. My tahoe does not have fog lights unfortunately.
John52269
J
JCSFPD
John thank you. You were correct about needing to have the fog lights turned off. The Intellibeam worked fine after I turned them off.
BadDaddy2003
