Rear Main Seal Leaking After Transmission Rebuild
John ThreeSixteen
We have a 2013 Tahoe LT with 5.3 liter. Transmission started slipping last November so we took it to a recommended transmission shop. They
actually did a nice job with the rebuild and now shifts great. The unfortunate thing that happened was a rear main seal leak that started about
two weeks or so later. They told us that the original seal was not replaced. I asked why and they said it was in good shape, or something to
that extent. They were going to charge $1600 to pull tranny and replace seal. We refused and took it to our local repair shop.
My two cents is I should have insisted that the main seal be replaced. I take responsibility...it was an expensive lesson. I hope
others here on the board don't make my mistake.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
What is the other shop going to charge you?
wjburken
Eastern Iowa
that extent.
I would never use that shop again. Why in the hell would they not want to replace a $30 part while the transmission is out other than have a way to get you to come back and pay them $1600 to do it later.
donjetman
Yes, it's one of those "while you're in there" things. Think about the following:
When I did our 07 6.2L rear main seal 5+ yrs & 63k miles ago, I also:
changed:
new torque converter
Tranny front pump seal – GM# 24237531
Tranny Input shaft seal –GM# 24219390
oil pan gasket
oil cooler blockoff plate gasket
changed the oil pump pickup tube o-ring
installed afm deflector shield
new starter
replaced leaky trans cooler lines
Also, you might want to change:
front differential mounts w/bushings
engine mounts w/H3 units
tranny mount
oil galley barbell
It hasn't needed much unscheduled mx since then. Has 193k miles today.
J
John ThreeSixteen
Yeah, it was a tough/expensive lesson to learn. You would think the transmission shop would
replace the seal regardless of how it looked.
My thoughts are to give others here on the forum a heads up and hopefully keep them from
loosing time and money as well as a lot of aggravation.
B-train
I ended up with the same deal on my used 2008 Denali. Trans was replaced at the dealership at about 120k. I bought it with 140k and it had an oil leak. Seller said dealership said it was the pan gasket.........it wasn't. Now I just park on cardboard. People who can't see the big picture and be proactive bug's me.....
89Suburban
SE PA
I have to park mine over the La Brea Tar Pits in my driveway. :(
wjburken
Eastern Iowa
I've owned old Land Rovers. When they STOP leaking it's time to worry.
Caddylack
YES you should have discussed this with the shop in advance, BUT…
A good shop doesn’t overlook stuff like that. They are supposed to be the experts.
Toenail
These people see the big picture but it doesn't have you in that picture. Only them and more work.
johnsonwillie199
