2009 Yukon XL Denali - Front & Rear Suspension Refresh
KraftMatic87
Hello all, I have a 2009 Yukon XL Denali that I’m looking to do some suspension upgrades on. I’m in the process of ordering the following parts for my front and rear suspension. My main question revolves around what front shock / strut assemblies I should go with if I’m looking to do away with Z55 AutoRide in the front? I’m currently considering either the KYB Truck-Plus or KYB Strut-Plus strut and shock assembles because they seem decent and are affordable at $175-$250 / piece vs. Z55 compatible shocks ~$500 / piece. I’m also deleting the air ride in the back and going with regular Bilstein gas shocks.
Front :
- Or -
In addition to:
Rear :
I went back and forth over whether to go with Bilstein 5100 or 4600 shocks in the rear. I’m not planning on installing a lift or towing so I figured 4600s would be the best option.
M&P Active MagnaRide / AirRide Delete resistors will be used on all four corners to ensure I don’t get any suspension dash lights or codes. I also have new sway bar bushings going in all around as well.
I have all the parts listed except the front shock / strut assemblies which I haven’t ordered yet. Anyone else used KYB’s on their GMT-900’s, especially in the front? Looking for any tips and suggestions. Thanks!
I don't believe that Magneride was available for your model year. As such, you most likely have the Electronic Suspension system on your truck. Your decision of course regarding the removal of the Electronic Suspension system on your truck is your to make. Lots of folks have done it, and some folks, including me, had the Electronic Suspension system removed, regretted it, and re-installed it.
The rear springs need to be changed to stronger springs if you remove the Electronic Suspension system, as the air bladders carried part of the weight load in the rear. So, when you order springs, purchase a spring that is compatible with the non-Electronic Suspension spring specification.
KraftMatic87
KraftMatic87
You're right, I got my RPO codes mixed up. I have the Z55 AutoRide system. The most affordable OEM Z55 compatible strut assembly I can find is $450 on RockAuto (DORMAN 949650) and I've not heard great things about Dorman suspension parts in general. For that price I can get two 'dumb' struts.
The Moog coils I have listed above are also compatible with non-electronic suspension. Doing away with air-ride in the rear because my compressor is dead and those air shocks ain't cheap!
Converting your suspension over to ZW7 is a downgrade, not an upgrade. She's going to ride like a buckboard with 20 or 22 inch wheels with dumb shocks.
If you are set on converting it, at least use the GM OE parts for it for the best ride possible.
KraftMatic87
KraftMatic87
I don't want to compromise my ride quality but I wasn't sure how easy it would be to forgo the electronic suspension / air ride without sacrificing ride quality too much. My rear shocks now aren’t holding air and my compressor is dead, so that would need to be replaced as well.
I might go back to the drawing board if I’m going to preserve my rear air ride and front electronic suspension since those are about $450/corner. That’s why I came here to ask though! Figured someone wiser than I would have some input.
donjetman
If you want to keep the Z55 air ride? Arnott sells rebuilt rear shocks (lifetime warranty), AS-2708, and a compressor, P-3242, all for less than $800, rock auto & amazon.
We purchased our 2007 Yukon Denali w/Z55 Oct of 18 w/130k miles. Today it has 193k miles. The rear air bladders and compressor were shot when we bought it, but It rode like a dream. We have not fixed them and it still rides like a dream. So, no plans to fix them. We don't tow or fill the seats w/people so no need to for the rear air bladders.
NotJLB
I converted to a Bilstein rear kit on '03 and '04 Escalades and highly recommend it. Much better ride and actually have usable suspension for towing.
91RS
GA
KYB is cheap stuff. If you’re going to delete it, at least use Bilstein shocks. Check Rock Auto for the best prices in the OEM shocks but make sure to have the part numbers based on your VIN from a dealer because there are a bunch of different numbers and they all look the same.
solli5pack
I replaced my front Z55 struts with KYB ASR4080's and installed Vigor air shocks and compressor in the rear. Truck rides great! 2008 Yukon SLT. It rides even better after installing 22" wheels.
HACK BLOCK
NYC
z55 suspension replacements are about 250 each. I just replaced mine last year with acdelco. arnott sells replacement rear z55's but not fronts. everything they sell for the fronts are conversions
petethepug
Michael
SoCal
This pic sums it up for me. Perfect day, perfect vehicle.
Not trying to be the Debbie Downer here but if you’re towing and potentially doing it with passengers as well as using it for a snow limo, wouldn’t it be a good idea to retain all the redundant safeguards of the z55 since it’s tied into all the other trucks stability systems?
The only scenario you can’t predict when you’ll want full blown micro second calculations made is after z55 is defeated and some FDS has hit your truck or forced you to avoid a collision.
I would never want to explain to my insurance or a State Trooper what the resistor is zip tied on to the body of my truck when it’s upside down from an accident another drunk, uninsured guy caused. That’d potentially be enough for the guy that caused the accident to flip things and him / insurance blame me for disabling a safety system.
Unlikely, yea. Possible, definitely. My family and the possibility of having regrets that 1% of a mod I did may have avoided bodily harm or worse, nope, pass.
If it were my personal toy I used for mostly Non Family stuff, that’s another situation entirely.
petethepug
Michael
SoCal
I know your hands are full with LT swapping that new motor in. My Indi wasn’t to happy about doing my trans 2x either.
The biggest difference you’ll feel in refreshing the suspension is, new struts of course, but new bushings and poly on the sway bars even makes the passengers happier. If you can pull it off get bigger sway bars to give it a better than new ride.
Check out my aluminum suspension rebuild page where you can swap in the 15-19 Denali alum susp parts when you’re refresh’g it. The cost is about 5-10% more but you’ll drop over 30lb off each front axle.
The part numbers listed for the Esky are the same as the Denali except for the z55 struts. I’m on a budget so the approx $1.3k in parts accumulated for the job from internet shopping equates to almost $4k in dealer prices.
Keep us posted on the motor transplant.
KraftMatic87
KraftMatic87
Thanks for the tips! Lookin to do suspension work this summer along with new fuel pump. We’ve been driving on the new engine for two weeks and alls well so far. That last block dropped an intake valve in cylinder 3 and made some nice tasty piston McNuggets. I have two and a half years before the engine warranty is up so if I can make a it a year with this block we should be hopefully be good.
KraftMatic87
KraftMatic87
I ended up installing a pair of KYB SRM 4079 Truck-Plus quick struts. I have bypass resistors coming in the mail tomorrow and I’ll be installing those to disable the service suspension light. I’ll be installing Moog 81071 springs in the rear with a pair of Bilstein 4600 shocks this weekend to complete the auto/air-ride delete, followed by an alignment. I may opt to replace the compressor and add air ride shocks in the future but for now I think I’ll be happy with the passive shocks.
Very impressed with how the KYBs ride. The front sits about an inch higher than before. They are firm but very responsive, and they recover quicker from bigger bumps than my soft worn out autoride shocks. My stock struts were so far gone anything would have been an improvement.
The KYBs were $500 for the pair. The Bilstein 4600s were $160 for the pair, and the Moog rear springs $70 for the pair. Resistors were $24 total, so I’ll be out $750 to replace all four corners. Definitely worth every dollar!
My next project will be replacing upper and lower control arms and inner and outer tie rods sometime in July or August. Someone help I can’t stop buying parts!
petethepug
Michael
SoCal
As soon as the resistors go in the truck is being told it’s driving 70 mph straight down the highway when you it may actually be ass end out in a tailspin trying to avoid an obstacle in the next lane.
ABS, Stabilatrac & Yaw sensors will be totally clueless where your wheels are and go into Godzilla mode or …
The truck may simply barrel roll. It is being fed data like it’s being picked up by Godzilla because all the wheels have the exact same bogus readout from the resistors communicating with the stability program.
KraftMatic87
KraftMatic87
I understand that the resistors are ‘fooling’ the ECU but here’s my question:
The ride height sensors are not being touched because I’m not lifting the truck. I only am putting resistors on the dampener connections for the front shocks that plugs into the top of the strut. I’m genuinely curious how that would affect my wheel speed sensors or put the vehicle into Godzilla mode?
When I do the rear shocks I will plug a resistor into the sensor that plugs into the shock itself. The rear ride height sensors will not have resistors plugged into them either.
petethepug
Michael
SoCal
All the live data that’s fed through the rear suspension module and other sensors are tied into the active suspension calculations for when & how much dampening & rebound the struts should get.
Later models after ‘10 also incorporate active sway control for towing, auto hill descent braking and uphill roll back brake assist when stopped.
The VSC or vehicle skid control is one of the most important features of this vehicle and why it was rated a 4/5 for rollover protection and 5/5 on everything else by the NHTSA.
Just be aware you’re knee capping the system that will totally stiffen to the max or soften one or more struts to prevent trailer swag or rollover.
Not trying to be dark, just pointing out the really of the dark side of folks that take zero responsibility for owners and their families who sell these “money savings parts”. Ask a dealer about it and all you’ll get is “NOPE, won’t do it”.
KraftMatic87
KraftMatic87
I understand what you’re saying now. I don’t ever plan to tow with this vehicle and that was one of the reasons I felt comfortable going with passive suspension. I never was planning to buy Z55 autoride / electronically dampened struts for the front anyways because they were $500/piece. But in a few years when kids get older and we aren’t paying for daycare I may buy a new compressor and air ride shocks for the rear once these Bilsteins start showing their age.
petethepug
Michael
SoCal
Again, not trying to be Debbie Downer. Front z55 are $3h ea and rear are $3h ea. Both have a 5% off discount. All guaranteed for life. Key word, life.
I did 3 kids in our 08 YXL Denali and locked up the truck in a full panic stop just once at 75 in the 6 years of ownership. They literally steer when pulsing and locking up (and letting off) the struts and wheels. GM’s system got 3 TONS of truck over two lanes and down to 45 into an empty lane.
My wife pee’d her pants. The kids we’re asleep. I’m lucky to tell a story about it than explain to some big shot patrol investigator trying to make a name for himself on what them devices are hooked up to the suspension.
KraftMatic87
KraftMatic87
I finished swapping out the rear today for my air-ride delete. Bilstein 4600 with Moog 81071 coil springs and Moog K160072 insulators on top and bottom of the new springs since the old ones were worn out. I’m completely impressed with the KYB / Bilstein combo, and the truck handles much better. The handling is firm and the new shocks / struts are way more responsive than my old worn out ones.
Glad I rolled the dice. Truck drives great and handles much better than before. Total cost was $750 in parts for front and back.
jkhuntzinger
