Put vehicle in Park/4WD/StabilityControl/Error
DustaRimes
2018 Chevy Tahoe LTZ 5.3L V8
It was running perfectly fine. About 30 minutes into driving it, and a block from home, the engine completely shuts off and I coast into my driveway. Now when I attempt to start the vehicle, it won’t even crank over and the dash says “place vehicle in park, 4WD, Stability track, roll down and then up drivers side window.” In addition to this, when you attempt to start it, it gets stuck in the accessory/on mode and doesn’t want to turn off. I have not a clue where to start!
check battery cables & grounds for beginers, the cables can go bad even if they look ok, use a volt meter.
schafer98
