Heated cloth
vcode
So my search didn't show much..... Can you add heated seats to a cloth equipped LS or SLE? It always surprised me that you could get heated cloth seats on other GM products but not a Tahoe/Yukon. Would the heaters from a pick-up work?
Big Mama
Virginia
I’d think a truck seat would work or you can go the aftermarket heater route. I did one on my wife’s old E39 and it worked great.
yes you can add heated & cooled or heated only
you need the seat & wiring harness the harness dr has them, if not on his webite then just message him he can make them
his stuff is top notch https://harnessdr.com/
you may need to add a harness/switches. etc to get heated if you do not have heated already
vcode
vcode
But what do you do for the seat itself? LS and SLE did not even offer that as an option.
vcode
vcode
I looked online and couldn't find anything aftermarket.
idealy you just grab a used seat from a wrecker, then it is already wired and ready to go
you can just add a seat heater with a manual switch if you wanted to go that route. this would require pulling the seat cover's off and putting the heater pads in and then wire up power.
heated seats work just like heated gloves or heated socks, etc it's just a wire grid, some higher trim models use a fan and heater module not sure if those are used on the k2's or not if so those would be on a Escalade or Denali
Big Mama
Virginia
Wes is right on the money with the easiest options. The kit I put in my wife’s rig was pretty easy to install. I used switched power from the stereo and put the toggle switches from the kit on either side of the stereo and ran the wires under the console for a clean look. We sold it or I’d send pictures.
Yote1
