Cd error
Novasmithjohn
I there a way to find what the error on a 1999 remote cd player is. I put the disk in it sounds like it’s reading but ejects and shows error on the radio screen
it's old, unless you feel like opening it up cleaning, lubricating, new drive belts if you can cource them, maybe a new laser. then it might be time to get something newer, there are a couple companys that make retro looking new radio's if the new look is not your thing
N
Novasmithjohn
it's old, unles you feel like opening it up cleaning, lubricating, new drive belts if you can cource them, maybe a new laser. then it might be time to get something newer, there are a couple companys that make retro looking new radio's if the new look is not your thing
Thanks, don't want to change the radio will look into a maybe a new laser
might be more than just a new laser, it is after all 25 years old. could be a cap, the circuit board, maybe it is just dirty, who knows.
nothing to stop you from trying though. good luck
I would definitely try cleaning it first and give the mechanical parts a little tiny of lube
N
Novasmithjohn
Used contact cleaner and caned air. Lubed what I could see without tearing it into small pieces. Will. Sear h the net and seeing there is a diagram on it out there. Thanks
It sounds like you need to replace the head unit as suggested above. Repairing/replacing components on these units is a very challenging and usually unsuccessful task.
YukonGTmaster
2 Door w/ Barn Doors Club
I had the cd unit apart before to change the backlighting, and to try and disgnose read errors. In the end I had to bite the bullet and buy a refurbished one off ebay. Pricey, but if you want the OEM unit, and you are not an electronics repair tech, it may be the way to go.
BadDaddy2003
