22 Tahoe with Water Leak
k1970
Oman
Sometimes I have the same, but at the rear glass.‍
VTJoeK
Do you have a sunroof? If so, it sounds like the water is not getting to the drain lines for the sunroof rain tray and jumps over the lip. Open your sunroof and look in the corners where the drain lines are located and make sure they aren't plugged with debris.
I do have a sunroof but the drains work fine. Thanks for checking.
noku
Thank you! That is exactly the issue.
Hi. How did this end up for you ?
I have identical issue with water coming in same spot. Right side of headliner. Now little on the left too.
3rd time going into dealership. Supposedly a GM engineer is going to check it out.
Just wanted to know how yours ended up, if it was fixed and what the actual issue was.
VTJoeK
Ok so we pinpointed that water only leaked in when the front wheels were elevated (parked in my driveway on a pitch). During driving i had no issues. The front drain lines worked fine and when driving could drain the whole roof as needed, but when it was parked and the rear drain lines had to compensate and drain the whole thing is when it would leak in. So the dealer really focused on the read drain lines and found them to be pinched from factory. They ordered new lines and replaced them and we have had some very big storms here in Maryland and NO LEAKS!! Tough problem to solve, but once they got it tilted they found the issue.
noku
Wow. That’s great to hear.
They called me this morning. Claiming that last time when they sealed the pinhole in a spot weld. That they didn’t seal the windshield entirely.
So they’re bringing a windshield company in to reseal it and they think it’ll finally be fixed. Heard it twice before, but we’ll soon find out.
Glad to hear yours is all fixed.
Cryptocap
Cryptocap
Mine ended up being resolved after the service department filled in the spot welds.
Tahoe2023
Damn that sucks.
We have the same issue? How is this not a recall? It is clearly a factory defect and a result of poor quality control. I BELIEVE if this does not come out as a recall then we have enough people here to start a class action lawwsuit.
What would be interesting to know is when the last time the spot weld machines were last calibrated.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Nope. I avoid any type of sunroof equipped vehicles like COVID.
wheelmanrob
Came to post about our CPO 2021 Yukon. We just discovered a water leak issue back in November. Thought it was from a small cooler we used on a road trip, but in late December found more water again in the passenger front footwell. I pulled some trim and carpet back and found evidence of water streaks down the firewall and the source of my bad smell in the truck. Thought someone had spilled milk, it was mildew. Dried and vacuumed it all up, took it to the dealer and they had a leak specialist look into it. They told me they resealed the windshield and it's on my invoice, but I didn't see any evidence of that. They probably didn't pull the glass and pulled trim and caulked? All I found some black rtv on the passenger door weatherstrip at the bottom though which was a half assed attempt. So I was already skeptical of the "repair."
A few weeks later, truck is just sitting in driveway out in the rain on a slight incline facing uphill (very slight) and I had wet carpet and water running down the firewall. Wife had to go use the truck so I put some towels under the carpet. They were soaked when she came home. This time I got pictures a short video. Took it back, and they had it for a week and couldn't recreate my leak somehow. We had a day of heavy rain and flooding, and it didn't leak for them. I'll be collecting more data on if it's worse while driving, how we park it etc. I'm sure this will take a few more trips to the dealer before its resolved. I'm going to pop my overhead console down this weekend to look at those spot welds for evidence of dried up water. I'll make sure to reply back after some time with what happened and if its indeed leak free. They may have shot some rtv around the windshield over those questionable spot welds, who knows.
blackelky
My Ram did that when I had it. They replaced the windshield westherstrip and the third brake light weather strip
WalleyeMikeIII
Sunny and Snowy Minnesota
THere is a TSB for this related to the Sunroof drains (see post 5 of this thread)... Ask your dealer to confirm it was applied.
wheelmanrob
We had some decent rain last night. Parked truck like normal on the driveway with a slight incline (truck facing uphill). I had a hunch it would leak and sure enough there was some water under the carpet again on the passenger footwell. I was able to locate the white sunroof drain hose and followed it to its grommet. There I found evidence of water leaking from beneath the grommet, going behind the insulation and down the firewall to the floor.
I had read on one of these forums that an owner had a leak in this location where the hose met the grommet. That appears to be my issue. Much rather have this problem than the pin holes in the spot welds above the windshield.
I'm hoping now that with the pictures and video they can fix it. Without parking it in on the same incline as my driveway, the leak would not appear for them. Hard to find the leak when it won't leak.
wheelmanrob
Recommend also showing them the link to the article I posted above…between those two, they should be able to get you squared away
Yes thank you for posting that. I printed it out for reference and hope to have that TSB completed. I just poked up inside the cowl with the borescope and don't see the drain hose extensions.
Cryptocap
Cryptocap
Hopefully that will be the fix. My service department appreciated the photos and videos when I brought those. They had it done in no time at all.
wheelmanrob
Well, my leak is "fixed." No more water coming down the firewall. I used the same inspection camera to see how the grommet was repaired, expecting to see gobs of rtv silicone around the grommet which I would have been ok with. To my surprise, the sunroof drain grommet (pictured in above post) was completely gone with the hole wide open and the white drain hose was extended with some clear tubing that ran into the right kick panel cavity. It's raining again today so it would be impossible to tell where the water is now coming out (if at all). I will test it in the dry and watch for where it exits the truck. I'm guessing someplace behind the front wheel, coming out from a pinch weld or something.
I was able to locate the end of the hose by using my fingertip as a reference. I popped a grommet near the door hinges and saw my finger on camera. I would have felt better if that hose had actually gone out that grommet and drained to the exterior of the truck (which is outside of the door weatherstripping area). Instead, water is just dumping into the inner body metal which I'm sure will rot things out over time right?
I am pretty sure this is not a GM approved repair. It was completed by a third party water leak specialist. Seems all the dealers in the area use guys like this, albeit different companies.
Someone please advise me here. Willing to escalate this or will take to another dealer. This is my third time in for the repair and they only found it because of my detective work.
wheelmanrob
I had thought the front sunroof drain hoses drained into the cowling beneath the windshield. This is a picture of the front sunroof drain hose PN 20973104. Unless there is another hose that extends past the grommet (bottom of picture) than it may be dumping into the same place as before, just lower down. I would be ok with that. I'm going to go poking around more with the camera today and confirm 100% if where the original drained to is the same as where it drains now.
wheelmanrob
Yes, bad grommet indeed. Just got back inside from probing some more with the inspection camera. I was able to get the camera through the hole of the original grommet location which was very telling. It was clearly the cowling area like I thought.
The new location doesn't seem to have any drain of any sort. The water will just fester there and drain between sections of sheet metal. Not a very good idea IMO.
So, I was able to confirm that the original drain is in a completely different area compared to the current situation. At this point I would be happy with the new clear tube being redirected out of the original hole and goobered up with RTV. If I could more easily get to the clear tube and the original grommet location, I would fix this myself and save myself the hassle.
Camera looking out original grommet hole towards hood hinge bolts inside the cowling area.
Cowling side drain, this is where the TSB 20-NA-219 extension hoses go to.
This is where the sunroof drains now, into a cavity on the backside of the door hinges. This angle is looking up towards the top to see if that's where the original grommet went. There are some holes, but none are round. Two completely different sections. One meant for water draining and the other is not.
Looking to the bottom you can see water collecting.
Water all the way out the bottom with no aparent exit.
CrackerJack135
