Want to take my 2010 Yukon XL Denali with 180,000 miles for a family trip from Michigan To Florida
Geotrash
Dave
Richmond, VA
As I'm thinking through all of this, should I be concerned at all about changing the trans fluid? If memory serves me right, I've probably done 1-2 trans flushes along the way. Now that I've learned the actual service vs flush is the right way to go, should I be ok on this? There are no issues with the transmission at all today.
Second question - I read that some people are using the engine mounts from the Hummer. Is this a better alternative?
I take my transmissions to a local lube shop that does a proper fluid exchange (not a flush, per se). Valvoline lube shops do it this way also. It's less hassle, cleaner, and I know it's a complete replacement with fresh fluid. Never had a problem in years of doing this with probably 10 different cars and trucks. It's worth doing it, in my opinion.
On the engine mounts, yes and no. They're a solid mount vs the fluid-filled original mounts, so they last forever but they also transmit slightly more engine vibration to the frame. I have the Hummer mounts on my 2012 with the more aggressive cam and I can feel it at idle whereas I couldn't before I changed the mounts. It's not annoying to me but it is noticeable. My wife can tell the difference so she prefers to drive our '07, which is all stock and smooth like butter.
donjetman
Pan needs to be dropped to change the trans filter. Filter can become clogged/restrictive from normal wear clutch material leading to issues.
B
bobby2175
So, just want to make sure I understand - does Valvoline do this by removing the pan and also replacing the filter
Thanks for the info on the mount. I think I'll likely go with the original mount.
B
bobby2175
Dang those shocks were definitely toast! Glad you got ‘em swapped out! Bet she rides pretty nice now on new shocks with the working air bladders!
It's crazy what a difference! After a while, you didn't even realize what was happening. I was constantly driving with the rear sagging - it just has a much different stance now.
Geotrash
Dave
Richmond, VA
Nope. Just a fluid exchange. When I want the filter changed I take it to a local transmission shop.
B
bobby2175
So, been trying to research and understand things much better about the truck and I see a lot of positive feedback on getting a blackbear tune and AFM delete and this seems to be something I want to invest in. Any recommendations there with current condition of my truck?
Also, after doing some additional research, I see that some people do a proactive replacement of the torque converter. I don't think I'd do this before my trip, but should I be considering looking for a good transmission shop in the area and doing this sometime next year?
B
bobby2175
#2 - Battery to frame is what I did. I put it under one of the three strut nuts. Removed the nut, wire brushed the metal clean, put the lug over the stud, reinstalled the nut with an extra ugga-dugga. That small ground that I think you're referring to is for the core support electrics, like the cooling fans. The factory battery ground is the 4 gauge that runs from the negative post on the battery to the stud on the front of the passenger side cylinder head. The ignition coil pack and core support grounds also terminate here.
#3 - It was another frame ground using the strut stud. The nearest bolt going into the engine block was that one behind the power steering pump that secures the bracket to the engine block.
Are you doing all this wiring upgrade stuff as part of your pre-trip maintenance? If your time is limited, I wouldn't worry about it until afterward when things calm down. There are much more pressing to-dos than the Big 3/Big 4. If the alternator isn't giving you any issues, leave it. If it does so happen to fail on the trip, it's super easy to replace in a parking lot. I think it's one of those items in the "may as well just replace the engine, trans, A/C evaporator, heater core, vehicle wiring harness, all switches and electronics just to be sure..." territory. Also, new does not mean fail-proof. Your alternator is working fine- it's tried and true, the devil you know. A new one could have a defect that is sure to show only during a road trip.
It seems you have a full plate with the cooling system refresh and normal pre-trip inspections and maintenance. Save the electrical upgrades for later tinkering.
@iamdub
Was hoping to talk grounds one more time to solve a particular issue.
We use the front aux input of the factory radio all the time. It's always had a whining noise come through the speakers when I accelerated. I bought a new aux cable today to replace the one that we've been using for the past 7 years and the sound quality is great, but the whining sound has also gotten louder.
After doing some research, it sounds like this could be caused by a bad ground. I've already replaced the negative battery cable and cleaned up the grounds it has. I've cleaned the battery terminals when I replaced this cable. I have to still do the two grounds at the frame below the driver seat and still need to figure out how to improve the ground from that inaccessible strap behind the engine. Any other suggestions on how to pinpoint this or make it better?
@iamdub
Ignore that braided strap at the back of the block. It's easier to make another ground for the body-to-frame (or body-to-engine).
Your radio or amp or any of the wiring in between could be faulty or have a poor ground connection. The amp for it is on the floor, inside/under the center console. I'd go after the radio first, though. Maybe run an external test ground from the radio chassis to the tube metal dash reinforcement.
In addition to that make sure the hood is grounded. The ground straps like to detach and disappear.
GMT900s don't have hood grounds cuz they deleted our damned under-hood light. :(
B
bobby2175
Thank you! I'm going to pull the radio tomorrow and see if I can fix it. Seems like the center console is pretty involved - that may have to happen after the trip and I'll have to deal with the complaints!
I'm also going to attempt to do my first ever oil change on any car or truck...I have a couple of videos - any whatchouts I need to think about. The tips you guys gave me on the heater hoses and the air suspension was really what made this stuff pretty easy!
I think the only questions in my mind are - how hard to tighten the filter and how much oil put back in (6 qts sound right)?
Well, that's a tease. Maybe it was optional? Or removed before you got it?
There's no evidence that it was removed and mine is the LT, so I would expect it to be there if it was available. However, I know that @Sam Harris' '03 Yukon has courtesy lights in the rear door panels, but mine has only reflectors. Not sure if that's the difference between Yukon and Tahoe or a change between the years. :confused:
Being that it only does it with the aux port (or is it also with the radio and/or CD player?) leads me to believe it's a fault within the HU. Could be as simple as a loose solder joint on that circuit. Simple, but not easy as you'd have to open up the HU and, even then, know how to trace and test electronic circuits. With the aux cable plugged in, does the sound change if you press on the plug end to move it in any direction or twist it in the jack or even slightly pull it in or push it out?
I've done so many that the tips and tricks are all automatic so I don't think of 'em. A few general tips that first come to mind:
Remove the oil fill cap and rest it on the spout to still keep it covered, but not sealed. I don't know how much difference it makes, but, my thoughts are that it lets air in so the oil drains out better.
Flatten out a cardboard box to put under the drain pan, favoring the right (passenger) side to protect the concrete until you're a pro.
I think one of the biggest issues is removing the old filter. So many shops overtighten them. There are numerous tricks with YouTube vids on removing them. Some involve attaining a better grip and leverage on the filter and some involve crushing and/or stabbing it with tools to have a handle. Obviously, you would try the non-piercing methods first to avoid the mess. Once you have it loose and begin to spin it off, oil will quickly begin to flow down the body. Some people hammer a nail through the bottom center of the filter to let it drain before they remove it. If you try this, have a really sharp nail and be in a position to hit it hard with a hammer. If not, you'll just cave in the center of the filter before you poke through. Once I crack mine loose and drain it, I grab it with my hand and forearm in two or three plastic grocery bags, each inside the other. These act like a loose glove while I twist it off. I hold it through the plastic bags and slide them up to capture the filter in the bags and tie it off. The filter and any oil is contained on the inside.
I start by pre-filling the filter. I flip it over inside the box to hold it upright, fill it and let it soak in while I remove the old filter, drain the old oil, remove the wheels (I rotate tires every oil change), etc. and come back to it to top it off and repeat as necessary. Between top-offs, I close the box lid to keep dust in the air from contaminating the oil since I dust off my brakes while I have the wheels off. I fill the filter until the oil floods the top and covers the smaller holes surrounding the large center hole, but remains inside the gasket. Then I use a small blunt punch to press the seal all around through those small holes to let the oil drain into there to soak the filter media from the outside in. When I'm done, the filter is completely saturated and full up to the bottom of the threads. I'm not on a time schedule, so why not take the time? Right before installing, I dip the pad of my finger in the oil in the filter and smear a light coat onto the gasket.
After you remove the old filter, oil will drip from those holes for a long time. My drain pan is big enough to catch that oil plus the oil draining out of the engine. If yours isn't, just drain and replace the filter first then drain the engine or vice versa.
Position the drain pan farther to the right than you might think it needs, but keep the edge of the pan still directly under the drain cuz it does drip there. When the oil first comes out, it's gonna reach about 12" from the drain hole, depending on how high you have the front raised. As it drains, it'll lose pressure and gradually reduce its distance. Slide the drain pan to follow it. I let mine drain and drip while I do all the other stuff.
After you crack the plug loose, keep inward pressure on it the entire time as you unscrew it. This will minimize the oil spraying all over your hand while you're backing out the plug. You want it backed out to the point you feel the starting point of the threads click against each other as you turn it counterclockwise with the inward pressure. At that point, the only thing holding the plug in place is you pushing inward on it, so you can yank your hand to quickly snap the plug out and away from the oil pan and the following stream of oil. I reach over the sway bar to grab and remove the plug so my hand is already above and to the side of the drain hole. The way this part gets messy is by someone not keeping inward pressure or it still has half a thread or so of engagement. So, when they try to quickly remove the plug, it snags and oil is spraying all around as they frantically try to grab the plug again to turn it that one last half turn or so. Then they drop it in the drain pan and their hands sling oil everywhere.
I keep a case of the Super Tech brake parts cleaner on hand at all times. It's cheap and works great for quickly cleaning the spilled oil off the oil filter boss, oil pan and sway bar. Wear safety goggles, keep your mouth shut and be mindful of where and what you're spraying to avoid splashback.
There should be actual instructions on this. Something like "turn until gasket makes contact then another half or full turn". I just go by feel. I use K&N filters which have a 1" nut welded to the bottom so I turn it with that instead of trying to grip the side of the filter.
I've always used 6 quarts. I have about 5.5 in the jug after filling the filter. 6 always puts it right on the line.
Interesting. I know they reduced lighting in the GMT900 (underhood, reflectors in the doors, etc.). Maybe they started weaning us off of them halfway through the GMT800 production years.
Geotrash
Dave
Richmond, VA
The only thing I would add to @iamdub 's excellent comments is to wear latex gloves when you do the oil change and keep plenty of rags handy. You don't want that used oil soaking into your skin. It's full of nasties, including a few known carcinogens.
B
bobby2175
Wow! Thank you for all of this! I'm going to give it a go in the morning.
As far as the radio is concerned, I tried to dig into it a little more so I could describe it better.
There is no issue when just playing the radio - it's only the aux port.
When I put the cable into the front aux port but not in my phone yet, there is a constant ticking that starts. The sound doesn't change at all when I'm moving it around in the port. When I plug in my phone, then it gets much quieter - almost to the point where I don't hear any noise. When I start driving, the sound increases with a higher pitched sound that corresponds with the transmission shifting.
I'm going to pull the radio tomorrow as well to see if I can find anything.
B
bobby2175
So, I found a local shop that I'm going to take the truck to next week to do all of the fluid changes. They seemed to be highly rated and when I was talking about the various items, it was clear that they had done some homework and explained exactly how they would do things (such as transmission pan, replace filter vs just a flush). So, I'm going to send them an email over the weekend and want to make sure this makes sense and covers everything I should be doing. Can you take a look:
1. Transmission service, filter replacement by removing pan. Do not perform trans flush. Refill with Valvoline MaxLife ATF (or should I go with AC Delco?)
2. Change ofront and rear diff fluid - AC Delcol?
3. Change power steering fluid - AC Delco fluid?
4. Change transfer case fluid - AC Delco fluid?
5. Replace driver side engine mount - genuine OEM part only
6. Overall vehicle inspection including the rod ends, ball joints, etc.
7. Check engine oil leak
8. Check diff leak
9. Fuel injector service
Anything I missed?
Drewphil
