- Joined
- May 9, 2018
- Posts
- 7,220
- Reaction score
- 14,055
It's an original tire from 13 years ago.How old is the tire itself?
Then the tire is junk. The rubber is beyond it's shelf life.It's an original tire from 13 years ago.
I was looking at that online as well. I'm going to get a new one. Will any tire shop put it back on the spare wheel?Then the tire is junk.
That’s what I was guessing. It’s on borrowed time.It's an original tire from 13 years ago.
That's what tire shops do.... ( ( ?? ) )I was looking at that online as well. I'm going to get a new one. Will any tire shop put it back on the spare wheel?
Just visit Discount Tire, in the area where you live....I was looking at that online as well. I'm going to get a new one. Will any tire shop put it back on the spare wheel?
I figured they'd take one look at the rust on it and say no.That's what tire shops do.... ( ( ?? ) )
First things first.... remove the tire and have the rim inspected. That will show you what your options are. Until then, you can only guess....I figured they'd take one look at the rust on it and say no.
I think this is an interesting option. There are a couple of powder coat companies around. I'll call on Monday and see how much it would be.+1 for replacing the tire. As for the rust on the wheel, it's just surface rust. If if it were mine, I'd wire wheel it, prime and paint it. No need to wire wheel the whole thing, just where the rust is and the surrounding areas where the paint easily brushes off. Or, have a tire shop remove the tire then bring the wheel and hoist assembly to a place to get media blasted. Pretty much every good powder coat shop can media blast. I'd say all those parts can be blasted with regular sand, no need to get exotic abrasives. Take it home and spray paint it. Or, maybe the powdercoat shop will hook you up. Then have your tire shop install a fresh tire. My point in having the tire removed is so you can clean and paint the inner lip as that can be a point of constant leaks if there is corrosion between the lip and tire bead.
Or, if the cost-versus-hassle dictates it, get a rust-free spare wheel and/or hoist to replace yours.
somewhere around there is fineWhat is the torque specs on the lug nuts? I was looking at another thread searching for the answer and I saw 140 ft-lbs. Does that sound right?
Thank you!somewhere around there is fine
yep book says 140
