My 2010 PPV
A
AV2010PPV
Note the rear window lol
A
AV2010PPV
The project keeps going. Added an SLP exhaust and vent shades. Used some Adam’s tire polish and interior detail to clean her up as well.
A
AV2010PPV
Decided to do some more maintenance. Noticed that the rear pad was eating at the rotor so decided to swap on all new pads and rotors. Easy project and the car stops significantly better. Also decided to swap in a new battery and new upgraded starter. While I was doing that I saw that one of the sway bar links was broken so I swapped in new ones. Car runs like a champ now.
A
AV2010PPV
Part 2.
Justinthewoods
Denver, Colorado
Sort of new to the forum but have surfed it a lot while looking for parts for my 2010 Tahoe PPV. I bought the car a few months ago with 150k miles but only 3k engine hours. I love this car and have replaced the following so far:
- New headlights with led bulbs
- New smoked fog lights. Had to hardwire in a switch.
- New GoRhino buddy bumper
- New OEM grilles
- Dipped the front and rear emblems black
- Dipped the oem mirror caps gloss white
- New OEM tail lights
- New spare tire cover dipped white
- New center caps and performance tires
- 50% tint on windshield and 15% on all sides
On the interior I did the following:
- New dash cover for cracked dash
- New steering wheel surround and emblem
- New radio screen with Apple car play and reverse camera
- Carbon fiber wrap on wood grain
- Used OEM leather seats. New seat cushion foam and cover on drivers seat.
- Wrapped the center seat in oem-type leather
- New A-pillar trim to replace cut old trim.
-Hardwired V1
-New rubber floor lining.
I then fully detailed the inside and outside. I replaced thar majority of the bulbs on the interior and exterior with LED bulbs. I replaced the oil, battery, and intake filter as routine maintenance as well. Here are some pictures:
I love the carbon fiber wrap you did over the fake wood!!! Could you explain how you did that possibly? Would love to do that in my 2010 Tahoe too! Thanks buddy, the car looks great!!!
Jimgeorge
Florida
What does hardwired V1 mean? There is discussion on here about heavy duty aftermarket sway bar. Lots of people said it is a huge improvement. My brakes were pulsing so my shop turned the rotor’s down instead of replacing with new. I thought garage’s didn’t do that anymore but they said if there is room it’s cheaper.
I don’t understand about spare tire cover. Can you explain?
A
AV2010PPV
I had some old wrap left from when I wrapped an emblem on another car. I was bored and decided to see what I could do with it. I used a hair dryer and a razor blade to wrap the wood. I removed the panels and slowly wrapped them. It’s fairly easy to do if you are patient.
A
AV2010PPV
Hardwired V1 means I wired my Valentine One radar detector via an add-a-fuse in the fuse box.
A
AV2010PPV
Where did you find the oem hitch and how much did you pay for it? 400+ seems like a lot to pay for a used piece of steel on EBAY.
You can get an oem hitch for about $100 from many junk yards. Removing the old bolts is the worst part of the process.
Jimgeorge
Florida
LQK, the largest junkyard in the United States didn’t have a single one anywhere in the US. Unbelievable.
A
AV2010PPV
I guess it depends on where you are. I just looked locally in Houston Tx and you can get several ranging from $65-$150. When I was looking I found four different yards selling them for $100/per.
Edit: I also see some one eBay for $200 shipped right now for an 07-14 Tahoe.
waveryd
IL
High 300s everywhere I look.
I just paid $158 today for one that they pulled and delivered from a local salvage yard today. Also included a semi-decent bumper cover. As has been mentioned, depends on where you are. I have an aftermarket hitch I would give someone that needed it.
Capybarbro
