Rubber Bumper Center Console
jaycough
Anyone found replacement rubber bumpers for cup holder lid, 2021 Denali Yukon. I lost one and can’t seem to find any.
Seymour
I’m in the same boat as you, just wondering if you had any luck locating the rubber grommets
Seymour
Was wondering if you ever had any luck locating the grommets. I could use 4 myself. I checked Dorman but I didn’t have any luck. Thank you
To whom is your inquiry directed? And are you looking for grommets or bumpers? Tried any of the the suggestions above?
cynistersix
Confirming on a 23’ Yukon the parts above did the trick. Pig tail side goes down in the empty hexagon shaped hole, a bit of spit to slide it in and good as new.
SeptemberC
@cynistersix Which part number did you end up ordering. This thread has two different part numbers listed.
Thank you
cmatt
I picked up both suggestions to determine which one is needed. The 22596346 is the correct one.
Tupapi
