My Aug of 23 Blackstone used engine oil analysis report
donjetman
This UOA report is about 0w20 synthetic "performance" motor oil that Superior Lubricants of Hebron, IN sales & distributes via HPLoil.com, and/or 219-996-3460. It's not their "race oil".
The vehicle is our 07 GMC Yukon Denali w/all aluminum 6.2L L92 with 190k miles. We've owned it for 5 yrs. It consumes about 1/2 qt per 5000 miles. The makeup oil was the same 0w-20.
This oil sample had 7400 miles in 153 hrs in 9 mths, mostly hwy miles, averaged 48+ mph and 17+ mpg.
DIC indicated 39% remaining when sample was taken.
The other results are as follows:
Samples #2 & 3 are the same load of Amsoil ASM 0w-20.
Sample #4 is Kirkland 5w-30
Samples #5 is Mobil Delvac1 ESP 5w-30.
donjetman
donjetman
In 2020 I modified this vehicle. I increased its oil sump capacity to 11 qts, added an oil cooler, and added a remote engine oil bypass filter setup (Amsoil EaBP90).
Our use of this vehicle changed mid-2023. We no longer are using it (as often) to make the 1000 mile each way trip between our TX and CO homes. So, I removed the above-mentioned mods and put it back together stock. The mods weren't as effective at increasing oil change intervals as I had hoped for. Nothing ventured, nothing gained.
Stock sump capacity is again 6 qts. The catch can I installed in late 2018 will stay. It catches 2 oz per oil change interval.
Upon receipt of this report I changed the oil to 5 qts Mobil1 full synthetic 0w-40 Euro and 1 qt Valvoline PB "Restore" (high ester) 10w-30, and the oil filter to a Fram Ultra XG10060.
What say U?
What say U?
All I can say is GREAT data. What I get from it is I feel better about not having a dual filtration setup. I've never heard of the Valvoline Restore. I'm not a fan of the lightweight oil, but my uses are much different than yours and heavier oil just makes me feel better about things. My Blackstone reports tell me it's fine. I'll be mailing them my most recent sample soon.
Valvoline Premium Blue "RESTORE" virgin/new oil analysis. Viscosity should read 11.7 not 1.7.
it's a unique oil that is no longer available. It was expensive because its ingredients are expensive. I got lucky and found 4 gallons on BITOG.
https://www.speediagnostix.com/new-oil-analysis/valvoline-premium-blue
The specs look to be quite comparable to Rotella T6.
Invalid link. Don't tease me.
donjetman
donjetman
donjetman
donjetman
Here's the T6 virgin/new analysis report:
https://www.speediagnostix.com/new-oil-analysis/rotella-t6
Here's the comparison of the two
Valvoline Restore 10w-30.........Rotella T6 5w-40
Viscosity 11.7 .........................................15.1
Oxidation 110 .........................................16.4
Calcium 900 ........................................2140
Sodium 0 ............................................5
Magnesium 1162 ..........................................86
Phosphorus 1164 .........................................1151
Zinc 1394 ..........................................1293
Molybdenum 69 ...............................................5
Boron na .............................................157
Silicon 9 ...............................................5
This is what I was reading:
j91z28d1
I'm not good with oil sample numbers. but am I seeing that 0w20 seems to have higher iron from ring wear than the 5w30 and test 5 was high from the over heat?
I'm a few 1000 miles from my next change and still considering trying the new amsoil 0w20 hybrid line. since my truck literally starts and stops the engine at least 50 times a day. but still calls for 5w30.
last oil sample of mobile 1 5w30 showed iron of 12 at 5100 miles on it, 2k of it towing a car on a trailer. engine at 150k.
think I can take anything away from your higher iron count from thinner oil that makes you think I should leave well enough alone.
donjetman
donjetman
Here are 3 previous used oil reports for the 6.2L, and a baseline (BL) or virgin or unused report. All 4 of these previous reports are about Mobil Delvac 1 ESP 5w-40.
The 3 best reports when looking only at Iron (Fe) ppm are:
3/29/19, Mobil Delvac 1 ESP 5w-40, 8100 miles, Fe=39 ppm or 4.8 ppm per 1,000 miles, 6 qt sump
7/24/19, Mobil Delvac 1 ESP 5w-40, 6,200 miles, Fe=40 or 6.45 ppm per 1,000 miles, 6 qt sump
8/22/22, Amsoil 0w-20 Signature, 6,235 miles, Fe=37=5.9 ppm or 5.9 ppm per 1,000, 11 qt sump
The overheat event (plastic heater hose T broke) happened 12 of 19. You can see how it effected the oil in the 3/20 report.
Its back to the stock oil system configuration now. I'm hoping that the next uoa report (in 2024) will indicate if the my mods were helping or hurting.
Charlie21ny
