Heated seats work sporadically
Codester69
Heated seats only work when they want to. When one works they both do, same when they don’t. I can’t find a schematic to show how the power travels. Does it go to the driver side first, or split before ? I’ve wiggled connections, and made sure everything is plugged in tight.
Sounds like there is a short somewhere. A bi-directional scan tool can read the internal codes and either tell you directly what it wrong or point you in the right direction without guessing. It's usually one of the heater elements has a short in it or the memory seat module. A new one requires programming.
You can get the wiring diagrams for your truck at AllDataDIY along with the troubleshooting guide for a nominal fee.
048tahoe
