YUKON 2022. Driving on AUTO Mode
ckikano
good morning, I have been driving the GMC Yukon SLT 2022 model for about 23,000KM on AUTO Mode. Will this have any impact on any system or equipment in the car?
AUTO (Automatic Four-Wheel Drive)Use when road surface conditions are variable. When driving in AUTO, the front axle is engaged, and the vehicle's power is sent to the front and rear wheels automatically based on driving conditions. This setting provides slightly lower fuel economy than 2 Mode.
PG01
Up here to the right
Like I’ve always said, there is no reason to drive these suvs/trucks in auto mode unless road/off road conditions call for it.
Yes I believe you are putting unnecessary wear on the front axle/diff if you drive in auto constantly. The selector is there for a reason, use it when conditions warrant. If you want an AWD vehicle go buy one, this is RWD platform with an option for 4wd. There were models that had AWD on previous generations of the vehicles but since the 2015 model year they have all had a SELECTABLE 4wd transfer case.
MY THOUGHTS/OPINIONS on the auto mode is just what the owners manual says and the way I read it if you don’t need auto 4wd keep it in 2wd. Basically, ‘Auto 4wd’ is just like the trucks from an era long ago… when you had to stop, get out, flip the switch on the front hubs from free to 4wd and then pull a lever in the truck to engage the transfer case. Yes I do believe you are putting unnecessary wear on the front axle. When you are in 2wd (free on the older trucks) nothing is engaged on the front axle back to the transfer case. AUTO locks the hubs (like switching hubs to 4wd on the older trucks) and engaging the front axle. At this point the difference between an old truck and a new one is the fact that a computer is monitoring wheel slip/speed…so if one wheel slips the computer acknowledges this and puts the transfer case into action sending power to all 4 (not really but everyone believes that so we’ll just go with it) and in an old truck you are that computer… if a wheel slips you pull the lever into 4wd sending power to front diff from the transfer case.
This is my opinion on AUTO.
Stbentoak
Mine has 26K miles on it and probably 200 of those were in any conditions that needed anything near 4WD/Auto mode. Mainly hydroplaning fears due to crappy tires!
Leave it in 2wd unless conditions really dictate something else.....Better for your drivetrain.
DuraYuk
I used to rebuild transfer cases and front diffs all the time from people driving in auto in dry paved conditions. System isn't designed like an all wheel drive. You are wearing components if the wheels can't slip (dry/paved conditions), especially turning.
tjs3922
Interesting info. I have mine in 2wd the vast majority of the year. In north central WI it gets used in winter a fair amount but even then not a lot. Good to know about not using it unnecessarily.
maybe, maybe not
my take on it is the wear is not as ******* the rear diff if the power is split
I have around 54,000 on my 18 and it has been all on "auto" with no ill effects
it's certainly not going to just break out of the blue simply because it's on auto
it does not state anywhere in any manual or book that you cannot or should not drive in "auto"
it only states exactly what you noted above, slightly less mpg.
DuraYuk
maybe, maybe not
Can you put your vehicle in 4 hi and turn on dry pavement ? Does it bind up? That's what happens in auto on dry pavement when the system engages especially in a turn. It's not designed for it and it will prematurely wear things out. Now if you use AUTO the way it's intended....random conditions that cause slip it will be fine. But on a normal dry day with no slip conditions present where the wheels actually lose traction you can prematurely damage components. If the system worked perfectly you wouldnt have to worry but even in auto it sometimes engages 4wd when nothing is actually slipping.
It was a good warranty pay so if you must do it do it while you have warranty.
PG01
maybe, maybe not
That’s one thing we will disagree on Wes. I just feel like it shouldn’t be done.
C
ckikano
How to know if the components might have been damaged? As lately I m feeling vibration in the car , though I have changed the whole set of tires? Also now, when the car on Auto mode and I turn the steering wheel on low speed, I feel like the tires are slipping
If I don't have it on I will wear the tires out from burn outs, lol and that is with 100% seriousness I have my foot in the pedal way too much to have it in 2wd, even driving the wife's 2wd we just got her im chirping the tires just just driving like I always do. If I wear out the front diff prematurely that's no big deal I can get them for $650 all day long. I will add that I have never felt any binding in auto doesn't mean it's not happening but I haven't ever felt it and I have pretty good feelers. I think the traction control does a pretty good job of detecting wheel slip and works as intended the front differential is a open diff it is not a locker even if 4wd is engaged
DuraYuk
Take it in and explain it to them. They can dig in to see what's going on. Put it in 4hi and drive and then put it in 2 hi and drive. See if you notice any difference. Only go straight in 4hi otherwise it will bind up.
Auto is not meant for dry pavement conditions.
C
ckikano
How to know if the components might have been damaged? Lately, I've been feeling the vibration in the car, though I have changed the whole set of tires. Also now, when the car is on Auto mode and I turn the steering wheel on low speed, I feel like the tires are slipping
Vladimir2306
It should not slip in Auto mode. In general, nothing will happen for 23 thousand km in Auto mode. There, the problem begins not with the bridge, but with the clutch unit that this front axle includes, and then on a run closer to 60-80 thousand and subject to a sufficiently active drive in Auto mode.
CTown Duramax
I've got 4WD and wish I didn't have it. Two winters now and I have not used it once. It's a $3k upcharge and hundreds of pounds in the front end. Growing up, everything was RWD and we did just fine. We lived on a mud country road and didn't need 4WD. All it took was a little skill.
Vladimir2306
Why did you buy a 4WD then?
Stbentoak
Except for resale EVERYONE expects these to be 4WD, you'll take a big hit with 2wd. Consider yourself lucky......
CTown Duramax
True here in New England - 4WD is all the dealers sell - but not the South and Southwest. The Tahoe has been very competent in the snow with these Michelin LTX's in 2WD. I guess 4WD would make a lot of sense if you're living in snow country or up a long private drive. IMHO, simple is best, get only what you need. That said, I love this truck, no complaints at all. 4wd is fine and maybe I'll have a use for it someday. The Tahoe handles great (in 2WD).
Vladimir2306
In general, it is, These machines behave perfectly in 2WD mode. We have snowy, cold and slippery winters in Russia, but I feel great on winter studded tires in 2WD mode. Including Auto only when you need to park in a snowdrift or leave it)))) 2WD copes with everything else.
PG01
Just make sure you excercise it every once and a while because that time you need it… well you know
1948Buickroadie
