Anyone running Spohn Rear Control Arms?
Byoung1330
Cookeville tn
That’s not a bad price. I wast 100% on the price I seen some on eBay a while back an thought they was around the price I said
67RS427
Shop around a bit, you'd be surprised... This place below I had bookmarked for years, I just saw they have them listed even cheaper. I remember talking to them and they use a different caliper in the rear (size of pistons) to better bias the brakes to compensate for the 16" front. I can certainly confirm that they stop this heavy truck really really well. It's so much better than stock or the power stop rotors/pads I had on before. It's insane TBH
https://www.littleshopmfg.com/gm-99-18-silverado-sierra-1500-front-16-tc6-big-brake-kit/
Looks pretty sick too
I’ve had them on for couple years. Never had a issue. Thanks tho. An I’m sure they do hold some heat in but I’ll take it for the look. I do want a set of Wilwood but that’s bout 5 grand
More like $3500 but it’s still a lot. I have them on both my trucks, the 16”/14.25” kits are what I got.
signguy62
NJ
Reviving an old thread.....
Would the Spohn boxed, non adjustable lower arms with poly bushings, work with the DJM trailing arm relocation brackets?
The DJM brackets would center the tires in the wheel wells and the Spohn arms would give you the added beef for less flex and wheel hop.
That is, if they would even work together.
Doug118
The djm brackets don’t center the axle. They just drop the back of the arm down to get a better angle for better handling and ride quality
you need a adjustable panhard bar to center the axle, I have the spohn boxed arms but stock height
I think he meant centering it fore and aft, not side-to-side. I'm sure you guys already know this: On larger drops that have the arms north of parallel with the ground, the axle is moved forward due to the arc of the arms. It's minimal, but noticeable if you study it hard enough.
signguy62
NJ
Panhard centers left to right. I have Spohns adjustable for that. The DJM trailing arm relocation brackets are for moving the axle back, in drops greater than 3in. Was just wondering if the beefier Spohn arms would work with the DJM kit.
But thanks anyway!
signguy62
NJ
The DJM relocation brackets move the axle rearward (back to center of the wheel well) in drops of 3+ inches.
But thanks anyway.
signguy62
NJ
I knew you knew what I meant. But I haven't been able to find anyone who's actually used the DJM/Spohn combination yet.
Well, except Tony....But he has a "better" product he's peddling these days.
I tried to find pics of mine from that angle. All I have are from the rear and under. I wanted to compare the factory arm mount on the axle to the relocated position on the DJM pieces to see if there was anything in the way a boxed tube might hit. I really think the factory stamped arms are taller and the Spohn pieces would have more clearance. I know this isn't a definite answer for you, though.
The pics I've found online of the stock arm compared to pics of the Spohn arms makes it look like the box part (the actual link) of the Spohn arm is a little shorter than the diameter of the bushing end. The "box" of the stock arm is the same height all the way across and over the bushings:
Doug118
But thanks anyway.
it literally drops the rear of the control arm straight down. The axle doesn’t move at all with that bracket. If it did, the pinion angle would change significantly and you’d have crazy vibrations.
Without that bracket, the front of the control arm would hit the frame during travel
