LED bar
Vladimir2306
Hello everyone, please tell me if anyone has experience with the maximum concealed installation of an LED bar on Yukon Denali?
On past cars, I put it under the radiator grille, but Denali has such a grille that there is a feeling that it will be very bad to shine through it.
There is another option, I saw a place under the number, which I circled in red, where there are plugs and, as it were, two protective plastic strips. It seems to me that if you pull out the plugs, then a 20-inch LED bar will fit perfectly under them
Just a question.... What is the purpose of this planned LED lightbar installation?
Vladimir2306
Vladimir2306
Hi all. It turns out that this niche in the bumper is for the intercooler of a diesel engine. On gasoline, it is closed, so it is great for installing an LED beam. In the service, they measured a single-row 20-inch beam on a black Yukon. Gets up great. And it's not very visible from the outside. For myself, I chose the Rigid model E-SERIES PRO 20" DRIVING Black 121613.
who came to the service. So we will put it in time))))
^^^^x2^^^^ Must REALLY need that extra light.
Yes, we have many places without street lighting for many hundreds of kilometers. And without markup))))
Great. I hope that it works out real well for you.
My town has no street light or guard rails or line markers on the sides of our roads. In fact large trees are commonly within 10+ feet of the asphalt edges. Fortunately, my aftermarket LED headlights give me more than enough light to navigate our roads.
Vladimir2306
Vladimir2306
Hello everyone) In general, everything worked out.
Let me remind you, I decided to put an LED beam in the lower part of the front bumper. As it turned out, this is a niche for a diesel engine intercooler, but everything is empty on a gasoline engine) We bought a 20-inch Rigid E-pro beam. Next, the master held the button in the salon. The scheme of work is simple. When you turn on the far beam through the relay, the beam is turned on, the button either activates the beam or deactivates it (that is, the far one turns on without a beam). Works great with automatic high beams too.
Vladimir2306
Vladimir2306
The most important goal was that the beam was not noticeable at a cursory glance at the car. This is what we have achieved. If you don't know where to look, you won't notice it.
Even turned on, it looks like just a bright spot from the bumper
CMoore711
This is a very nice high beam upgrade! I can't get over the brightness and throw of the light output from this. Very clean and sleek install as well, nicely done.
Vladimir2306
Vladimir2306
Thank you. Yes, they set it up very well.
Here's another photo I took. to trees 200 meters. Established high beam and high beam with a beam.
Dh1280
