2012 linkage issue
Masonisking
Hello, I’m not sure if this is the right place to post this. However i drive a 2012 tahoe, and just recently my linkage has been acting up. it started when the factory linkage part feel off while driving. I went to autozone and got the part and replaced it. however now it just falls off randomly. Seems to be mainly whenever i go into park so i have to reconnect it to change gears out of park. But the past few times iv been stuck in reverse with it. Anyone know any fixes for this?
j91z28d1
I think there's some good into in this thread.
It is proper to replace the entire cable assembly.
petethepug
Michael
SoCal
GM makes a 1/2 cable repair kit as well as SKP. Verify your fitment for any differences in 6.2, 5.3, XL and 4 or 6 speed.
I used the GM version of this one. It’s a timesaver as you don’t have to monkey with the cable up in the dash.
Onlyone
New Mexico
I ordered the new GM cable from Rockauto with the intention to replace it. I said screw it and just swapped out the bushing. Expensive little bushing. Lol. Worked great.
petethepug
Michael
SoCal
These 1/2 cable kits are for when the expensive little bushing, little bolt and bailing wire hacks have left the shifter felling like stirring mamma’s Mac n cheese. Eventually you’ve gotta fix it so the Mrs. isn’t stranded with the kids on a 100+ day.
Our trans was sitting on top of a tool chest being rebuilt. The diesel tech didn’t have to ask me twice to fix it once.
M
Masonisking
Thank you! i’ll try this. How hard was it to replace?
after going thru a couple replacement parts that would also just "pop off" I drilled a small hole in the nipple and used a cotter pin
I ended up using a FITZALL T74498-1A replacement and went ahead and used my cotter pin fix as well and it has been fine for quite a while now
this would be the one needed for the 6l80
wcrisler
The Fitzall solution is very simple. They have a great application chart that makes selection easy. I'll try to attach it here.
  • shift-cable-chart-hoz.pdf
just to update the fitzall has been working fine for me with my cotter pin as a secondary measure, I threw a spare in the center console just in case
justinakay79
