15-20 yr old plastic likely to breakWhy not buy a used one?
This tool is not good for those 1/2 heater lines. It did not slide into the line even after I spit on it and hit it with the sauce. So I did what i should have done Sunday, cut the section of below the ac drier, ran 1/2" gates heater hose and some clamps. Problem solved. I'm just going to use some of the hose clamps I ordered tomorrow to tidy up the routing of the new hose. Probably get some pics up also.
In May of 2021 I replaced the oil pressure sender (at 227k miles) but I doubt that would be the culprit since I've changed the oil several times since then. I did make a ~1,900 total mile road trip to southern CO and back the last week of June, I wonder if running the motor that hard that long might have had something to do with it. I changed the oil when I got home and sent it off to Blackstone which is what I posted above.
Might as well do them all while you're at it.Pulled the HVAC control last night and disassembled in prep for backlighting bulb replacement. I'm not sure if I'll do them all, or just the four that are burned out. Saving the work for this afternoon when it's hot outside.
Before: the button lights are easy to tell, but can't really tell on the two dial backlight bulbs.
Powered up on the table:
Dang I really need to do mine=(. Bulbs and new soldering station have been in garage about 3 months now.Pulled the HVAC control last night and disassembled in prep for backlighting bulb replacement. I'm not sure if I'll do them all, or just the four that are burned out. Saving the work for this afternoon when it's hot outside.
Don't feel bad. Mine are completely burned out--least of my worries right now.Dang I really need to do mine=(. Bulbs and new soldering station have been in garage about 3 months now.
I don't see how the tool can be modded. It's all good. The lines were at minimum 1/16 thick after I cut them, so no way that tool with 1/2 OD was going in. Clamp job working just fine. I did order some nicer stainless steel fuel line clamps to use instead of the regularl worm clamps on now. I had some but not big enough for the 1/2 gates heater hose. BEEN driving it all day and sealing just fine. The heater hose makes a loop near the reservoir and goes back down behind the AC drier.Whale, shit. I wonder if those aluminum lines are thicker than normal, making the ID too small. Maybe the tool can be modded?
I hear you but I have a spare I started on, pack of white leds and a new soldering station in my tool box. Maybe after I enjoy the new engine a bit more. I may start collecting parts for the NNBS/TBSS swap here too. Behind my wife's back!! Hahaha!!Don't feel bad. Mine are completely burned out--least of my worries right now.
I used -10AN line clamps to keep them routed nicely.
Nah. I just threw it in the tool box. I spend more money on clamps overall then the tool itself. I'm sure I can use it for something as long as I don't forget I have it.Clean job!
Wanna offload that tool? I'm still contemplating dickin' around with mine one day.
I appreciate the offer, unfortunately it's the manual control unit.Send it to me and I'll do the backlighting for you, if it's the AUTO control.![]()
That would be cool. I still don't have it back yet, the mechanic still has it and I don't want to rush him.I could do that one as long as I can get the slider knobs off without breaking anything.![]()
You’ll have to share a photo or two of that “oops”. It reminds me of when I was out of town and my wife had some brake work done on her previous car. She kept hearing noises and the brakes were “weak” feeling. I pull the tire off and the stealership forgot to use threadlocker on the caliper bracket bolts and the caliper bolts. Some people might say that it’s not needed on the caliper or the bracket, but this was an obvious case where something was needed.Fixed my suspension clunk.
Totally my fault and could have been catastrophic. I'm a dumbass. So, rewind to 2017 when i'm launching the parts cannon to try and fix my steering issues which later turned out to be an upside down centerlink thanks to the clowns at Firestone that did my tie rod ends.
Couldn't get the darn spindle to separate from the lower BJ and every YouTube I saw had someone hitting it with a BFH. I tried and tried, no luck. Apparently, when I was banging on it, I also banged on the top of it and compressed the metal to where the brake line bracket bolt wouldn't screw in. Here's the idiot move - I just sent it. That's right, for 6+ years, that brake line bracket was loose and flopping around.
Fast forward to the last 6 months or so and I have this super odd clunk in the front left.
My mind can only think that if I kept driving like that, the lines could have worn through and I'd have NO BRAKES! Counting my blessings that it didn't happen in the last 6 years. Is Powerball jackpot huge again? Whew.
Same color and body as my ‘02. Looks clean. The only difference from the outside is that mine has a chrome grille and a different set of wheels. What’s your current mileage?Basic driveway car wash for my 2001 Yukon. Nothing fancy. Original paint has some dings for sure but this SUV cleans up well even after twenty years.
Looks clean. What was your total damage and how long do you think it took you to replace them?New bulb (left, as if you couldn't tell) vs old (well done) bulb:
All the old bulbs and filters. I was surprised that none of the filters had melted to the glass, so I have these as spares now.
