Any amateur radio operators here?
Ghost10
Looking to install a NMO on the roof.
I have been using this setup for several months but would rather have a real feedline from the roof. Since I am a one man show and don't know anywhere to go to have it done, I decided dropping the whole headliner would be a real PITA for me, and have been thinking a NMO could go here? It's the rear side of the sunroof opening. Theirs room for me to stick my tiny hand and install a NMO there.
Watcha think?
This is what I have right now:
RedInCo
Ham with a 2010 Yukon Denali here. I have not done a permanent antenna install.
So you are thinking to have the coax enter the cabin at the edge of the sunroof trim, and run it over to a pillar, with it visible? That is certainly easier than dropping the headliner.
Ghost10
Ghost10
Current antenna pic did not upload
pretty much what I plan to do is, remove passenger sun visor, "oh shit" handle pull down that quarter of the headliner down and mount the NMO between sun roof and passenger window.
BTW I have a 18 Tahoe and the backdoor / hatch, I assume it's aluminum but with a continuity meter it is not what I would want to have a antenna mounted to.
My current radios are a XTL5K T Band and a APX8000 HT
I recommend to buy the proclipusa stuff for the truck vs holes everywhere lol
iLikeEggs
Potato!
Oregon, USA
I have a 2011 police Tahoe. It came with two NMO mounts already on the roof but I had to replace them. Once I pulled the rear overhead light from the headliner I had decent access to reinstall the NMO mounts and run coax where I had to. Yours may be a similar situation.
Solace
NJ
You can get a fender mount NMO if you don't want to drill your roof. If you do wish to drill your roof, your best bet would be to find a local emergency vehicle upfit shop near you to have it done.
iLikeEggs
Potato!
Oregon, USA
I picked up my fender NMO mount from Ham Radio Outlet. You can get them from Amazon and ebay too.
Ghost10
Ghost10
I have a tv on the roof in between the front seat and midrow
Don't see screws to remove it
Ghost10
Ghost10
I still haven't had time to drop the headliner and install a nmo. I did do a half asleep purchase on Amazon for a fender mount lol my only gripe is that it mounts way towards the front end of the truck and not closer to the firewall where there is a hole from the factory
May I ask how you ran the coax into the cab from the fender mount ?
Synchros
I did the same (fender mount, passenger side). I'll see about getting some pictures. Also put dedicated power to the fuse box.
This is in a 2018 Yukon XL Denali.
Ghost10
Ghost10
Synchros
This is how my 2018 Yukon XL is configured. The mount is a Comet CV2ANTNCG (https://www.dxengineering.com/parts/cma-cv2antncg). I already had several of the Larsen NMO mounts. I do want to add a ground strap to the mount.
I have cut a few sections of clear PPF to protect the paint where the mount could potentially rub. Performance has been satisfactory. I'm too often traveling with a Yakima-branded photon torpedo on the roof to have a roof-mounted antenna, though I'd much prefer that. I do have power directly fed to the radio from the internal drivers-side fusebox.
Happy to answer any questions about it. 73!
iLikeEggs
Potato!
Oregon, USA
View attachment 387494View attachment 387495
I would power the radio directly from the battery. Its easy enough to snake through somewhere on the firewall. Just run your fuse in line. Sweet set up though!
GeroniMoe
South Shore, MA
Looks like you have that installed on the passenger side. All of the info I can find on that mount specifies it can "only" go on the driver side (which didn't make any sense to me) - any insight on that?
Thanks!
- Scott (W2EMT)
Synchros
Thanks!
- Scott (W2EMT)
Sorry for the delay!
I didn't want to put it so much in my field of view. It didn't seem out of the ordinary to put it where I did. It continues to operate just fine, in my experience. My VNA approves of it.
iLikeEggs
Potato!
Oregon, USA
I put mine on the drivers side mostly because of the shorter coax run. It's not that much shorter really but I don't see why it can't go on either side. Just personal preference. The fender is a better bet for a decent antenna though. Number one, you can get a fairly full sized dual band on there. (mine is an MFJ-1422). Number two, anything beyond a stubby on the roof will likely hit things. I have two NMO Mounts up top and had a 16" Tram up there. One day it took a hit in parking garage and slightly bent the roof a bit. That's when I went fender mount. Now I just have a stubby up top for GMRS.
