Park assist Retro. Yukon
DxOCD
Can you take a picture?
Damaged also. Passenger rear door sill trim not reinstalled correctly either. They have ordered some replacement parts. Also broke the cargo net hook plastic cover.
StephenPT
St. Helens, OR
Rookie tech on the job that day. Didn't bother to read SI for removing that trim panel and tried prying on the arm rest. That arm rest is heat staked onto that sidewall panel and NOT removable. Glad they are going to take care of it and order replacement parts for you. Hopefully a more experienced tech is on the job when they get replaced as it's an even bigger job to replace the entire panel.
Crzylgs
Sorry that happened. That is terrible. I hope you are able to get everything back to what it was prior to the repairs.
thill466
Dealer called my parts are in, retrofit next week. They said 1.5 hours install time.
I highly recommend calling and asking the status of your retrofit. My original dealer took my VIN and said they would call as soon as parts were available for order. I got my oil changed at a dealer closer to me and asked them about availability and they ordered the parts and now have me scheduled next week to install. Still no info from original dealer.
dcyy
My front/rear park assist features were installed today 7/26..they were ordered by my service mgr. 2 weeks ago after she notified me they were available.Never received a letter from GM like I was told so if you are still waiting have your serv. dept. order them-they're in stock
Tinbadtin
Technician did not reinstall my rear trim correctly, ugh. Now have to go back in. Not overly impressed with the feature. Doesn’t seem very responsive.
Exactly. I wondered if there was a setting somewhere. Doesn’t seem to be. Luckily I got used to the size and able to park pretty effortlessly, even in small spots, without the assist. Probably helps one of my first vehicles growing up in narrow European streets was a 72 Suburban :)
DxOCD
Where can I find the si for this cause that makes me even more mad
WilliamMunny
I have had my 22’ Tahoe LT for 8 months now and waiting for the parking assist. I have had no issue with it, hope they don’t mess something up.
If Chevy wants to sell $60k-$90k cars they really seem to need to up their service game. A $40k bmw would seem to get you better service.
genestoy
Arizona
Dealer got my park assist part in, taking Yukon in Monday for install. Still nothing on heated steering wheel retrofit after 16 months!
DxOCD
They really scratched up both panels on a guy on the Facebook group. Check your cars out, back panels both sides. Or better yet, ask before they do the install how many have they done and how will they do it!
genestoy
Arizona
After waiting 16 months for my park assist retrofit I finally got it installed today! It works perfect and glad to have only one more retrofit to have done, the heated steering wheel. Dealer says they have been doing Sierra pickups so should not be too much longer for the Yukons.
genestoy
Arizona
Go figure, dealer calls me today and says my heated steering wheel retrofit is now available, two days after I had it in for the Park Assist retrofit!
dcyy
Finally got my official notification by mail from GM stating that my 16 1/2 month wait for front/rear chips is over and to contact the dealer...who coincidently installed them 2 1/2 weeks ago!
genestoy
Arizona
Yep, I never received anything from GM yet, my longtime service writer has been on top of mine and called me immediately when the system notified him my retrofits were available.
DxOCD
Rear panel replaced today, alignment still crap. Make sure your service tech knows what they are doing on park assist retrofit. They should not have to take all the seats out or the back quarter panel out. Sounds like the experienced tech that I had today would not have had me in the predicament I now find myself in. Panel #3 now ordered.
At least my heated steering wheel looks right
WalleyeMikeIII
Sunny and Snowy Minnesota
And significantly higher costs for regular maintenance....I priced an X7 before buying my Yukon. Then asked the salesman to pull out the maintenance schedule. I walked back to the service drive and asked the costs for the scheduled maintenance items...then I realized how the dealership could have the nice leather chairs in the service waiting area, the gourment coffee, and the scented air in the dealership.
genestoy
Arizona
Yep, I had the oil and filter with tire rotation done on my 22 Yukon 2 weeks ago when in for the retrofit and it was $179!
Tinbadtin
It really all depends. One thing to keep in mind is with BMW all services for the first 36k/3yrs are free. I just paid $230 for the 2nd oil change on my Suburban diesel, that didn’t even include a tire rotation. Comparatively oil change for my X7 M50i past the first 3 years is under $200. Yes definitely the consumables like brakes/tires will be more expensive and you will go through them quicker but you get much better ride quality and handling in return.
Lastly it used to be true that GM truck based platform was pretty bulletproof and could run many years on oil changed alone. In the new era of heavy electronics use I believe this is no longer the case. My last two GMs (19 Silverado and current 22 Suburban) have had glitches in first year of ownership like a check engine light and Suburban completely stalled and fried transmission module with less than 5k miles on it. Ironically both of our X7s have had no such issues with 30k+ miles on both.
I plan to keep both the X7 and Suburban long term so it will certainly be interesting to see how they both hold up as they age and rack up more miles..
BadDaddy2003
