2011Tahoe recommended inner door liner (rubber).
The Grey Beast
So I’m looking to replace my rubber inner door liner for the driver and passenger side doors. Is this something that can be changed out as a novice or needs a shop to complete this? If I did it myself what kind of tools will I need? Also do you recommend all Door liners be changed out at the same time?
Thank you.
Ken
The Grey Beast
The Grey Beast
Also do you recommend a particular company that makes the liner.
Ken
Thank you.
Ken
Are you talking about the gasket on the body that seals the opening when the door is closed? If yes, I recommend GM OE and they are simply friction fit, you can do it yourself. Same for the drip weatherstrip above that goes over both doors.
Replacing those is my July project.
The Grey Beast
The Grey Beast
i
The weather striping is what I meant to say. That goes around all the doors. I’ll check the GM OE. Thank you.
Ken
alpha_omega
Michigan
22766409 - Weatherstrip Surround Front Door (Drivers Side)
22766410 - Weatherstrip Surround Front Door (Passenger Side)
22766416 - Weatherstrip Surround Rear Door (Driver & Passenger Side)
20789461 - Drip Weatherstrip Front & Rear (Passenger Side)
20789462 - Drip Weatherstrip Front & Rear (Drivers Side)
20835970 - Weatherstrip Front Door Lower Auxiliary (Drivers Side)
20835970 - Weatherstrip Front Door Lower Auxiliary (Passenger Side)
20835978 - Weatherstrip Rear Door Lower Auxiliary (Drivers Side)
20835979 - Weatherstrip Rear Door Lower Auxiliary (Passenger Side)
*mind you this is for an ‘11 Denali, so it may be different for you.
The Grey Beast
The Grey Beast
Alph_Omega thank you for taking the time. I ordered the driver and passenger side door weather striping and the OEM CODE looks the same for both. I will reference this post in the future.
Don’t laugh but what does the auxiliary weather striping look like when attached. I’m having a hard time imagining it/ swing it. I’ve tried to put the code in and see what it looks like attached. Guess my best option it to look at my Tahoe.
P.S. sorry (all) that I’ve posted in the wrong section. I promise to work on that.
Thank you.
Ken
alpha_omega
Michigan
Ken,
It’s basically just a strip at the bottom of the door. It attaches to the door panel itself, sandwiched between the inner portion of the door and the outer portion of the door panel.
You may not need them. Those numbers are from a reference list of several part number I have gathered for my Denali over the years.
St. Louis
I just recently replaced the drivers door weather strip surround on mine with the OE part. It was rather easy. Makes sure to start at the bottom near the middle. You will see what I mean when you take off what's on there.
Also, just a side note on the part numbers listed above for anyone looking....Those would be for a Tahoe/Yukon, but the rear doors are different/bigger on a XL/Suburban and would probably have different part numbers for the rear doors
CKendrick
