Code 3782 AirFlow Control Feedback Circuit Malfunction
Foggy
KS
Code 3782 Popped up , along with a bunch of others that cleared and did not come back.
Went out yesterday to start the Yukon and absolutely no power.
Put the charger on overnight. Battery tests out fine. (it's only 3 months old).
Anyone ever run into this code ???
I did do a search, but found nothing on our GMT900's specifically
F
Foggy
KS
This is the airflow control feedback circuit malfunction...
I could go in and do a relearn of the all the actuators I guess..
Just couldn't find anything pertaining to our trucks and
maybe a reason why my battery went dead mysteriously
Any help is appreciated
randeez
south florida
Is it going into limp mode?
Nevermind, thought this may be a throttle body problem, you're on your own for ac problems
just a stuck or malfunctioning actuator, most likely unrelated to a dead battery.
probably going to need to replace the actuator though if it is causing hot/cold to blow undesirably.
might want to do a draw test for the battery drain.
F
Foggy
KS
So I went out and cleared the code twice... Still came back...
So with my bi-directional scanner I did the Actuator Relearn Procedure
Code did NOT come back (yet)
Still no idea why for the 1st time ever my battery went dead..... Yikes
Enoob
Foggy - did that issue ever come back after the re-learn? I have the same code (3782), along with B0433-04 and B0413-04 and interestingly, my battery shows low shortly after turning off the Yukon. New battery and fairly new alternator that both check good.
Dh1280
