Dim Low Beams 2016 Tahoe
scarbogarage
On my 2016 Z71 Tahoe, recently purchased, the low beams have very low intensity. Saturday night was the first time to drive it after dark and I could hardly see anything on the road. Last night I went out and with it running and in gear, using a flashlight on the sensor, I compared the DRL and low beams. The brightness is the same, DIM. What would cause the headlights not to go to full brightness? They work normal in high beam. Everything on Tahoe is stock.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me in this area will chime in.
scarbogarage
scarbogarage
Thank You Joseph!!! I will have to get some cleaned up photos but i have been on the road the past two weeks. I look forward to learning the unique qualities of the Tahoe/Yukon/Escalade line.
On this 2016 I am looking for the relay that controls the low beams and start my troubleshooting there unless someone else has a good starting point.
Vladimir2306
The halogen light in the tahoe has always been very dim. In mine, I changed the lamps to Osram nightnreaker + 110%, it was noticeably better, but did not change the problem. Now acquaintances on the tahoe k2xx are changing the blocks inside the headlight to diode modules. This solution is just fantaastic
scarbogarage
scarbogarage
I have gathered that from some of the posts I have read. The thing that baffles me is on my Tahoe the light intensity from DRL to low beam doesn’t change at all. Even in the transition it doesn’t flicker or blink it stays the same low level.
Vladimir2306
I don't understand a little. DRL and dipped beam are different headlight units. DRL is a diode strip that separates the near and far blocks of the headlight. and Low beam is the upper headlight assembly. Do you mean that the strip of diodes does not get brighter or dimmer when switching to DRL and Low beam?
scarbogarage
scarbogarage
My understanding, and correct me if I’m wrong, on the 2015-2017 Tahoe the DRL are the low beam at a reduced brightness. They didn’t go to the DRL on the LED strip untill 2018?
Currently as I test my Tahoe with the headlights on in auto at night and compare to the DRL, tricked by a light on the sensor, they both are the low beam (upper) headlight and have the same intensity no matter what mode it’s in.
Vladimir2306
Hmm, I just had a Tahoe 2015 with a diode tape. Here in the photo the dipped beam is turned on forcibly. but the diode strip is also visible. Accordingly, in the DRL mode, only the diode strip shone, and the low beam was turned off
Sam Harris
Any difference if you manually turn on the low beams, rather than using the auto-on sensor? Seems it could be a bad light sensor, or wiring.
Vladimir2306
I don't remember how on the k2xx generation, but on T1, if you turn it off, everything goes out. And the DRL does not turn on
scarbogarage
scarbogarage
I guess I will have to dig deeper into this. But I need to clarify that I am talking about vehicle running and in drive without the parking brake set.
scarbogarage
scarbogarage
No difference at all, same dim light. On the county roads at night it was hard to even maintain a good speed when I couldn’t use the high beams.
Vladimir2306
Yes, it is. The car is stationary, the engine is on, parking mode, the parking brake is off. It's the same in drive mode
Vladimir2306
Maybe your car previous owner did something wrong with the headlights
Tahoe_Life_
From what I recall, 2015-2016/2017 LS/LT Tahoe/Suburban and corresponding Yukons had the DRL as the high beam bulb at a lower intensity, and 2018+ moved all models to the LED strip previously reserved only for the models with HID headlights. I’m wondering if your light sensor might be out? When you are comparing modes, are the taillights turning on and off appropriately?
RST Dana
OH
2016 uses the low beam as ddl, not the strip unless you have purchased an plug converter from cmatt.
Vladimir2306
It turns out that in Russia, tahoes came with more advanced headlights, because we had DRLs that were a diode strip from the very beginning, since 2015. My car is just 2015 and the strip can be seen in the photo
RST Dana
OH
I’ll remember that as a disclaimer to my post next time.
RST Dana
OH
What do you mean? What disclaimer?) I did not get it
When I offer advice about ddl for K2xx, I will say “except if have a ride from Russia”, because they are different.
curbud
