blueinkd
- Joined
- Nov 21, 2017
- Posts
- 646
- Reaction score
- 1,558
05 Tahoe on +300K miles, 2WD, Daily driver/mobile office.
-Shortblock is headed to machine shop tomorrow for a bottom end rebuild. Using Scroggins Machine shop here in Houston.
-Looking to get another 300K miles from the refreshed engine. Cam bearing walked out during Cam removal, which lead to this rebuild.
-Getting a basic rebuild, which includes block inspection, honing, ALL bearings replaced, piston rings and some ARP hardware on the rods.
-Crank/rods getting inspected as well. You all get the picture.
-Machine shop doing the reassembly of shortblock and I will add the heads/cams/timing set when I get it back.
-I will be installing NEW lifters, oil pump, timing set, BTR Truck Norris Cam kit and new gaskets all around.
-New Rear main seal. Current ACD unit is less than 12 months old but might as well.
-The BTR Cam kit I got doesnt require a stall BUT I will be replacing the factory TC with another OEM torque converter.
-I do have a TBSS intake sitting in the garage, but that will have to wait until later. For now I just need the truck back on the road unless I can find all the missing components at a reasonable cost.
During the removal, I noticed the factory steam ports at the corners of the heads a bit ugly. Can anyone recommend a good replacement kit?
I see ICT has some nice options but way too much to sift through for what I need. Please point me in the direction of a simple replacement kit.
Any other things I should look at replacing on the engine while its out? Any complete ground strap kits I can buy that will include all grounding points?
I have already replaced the following items in the last 12 months:
-Coolant hoses and Tees.
-Water pump/thermostat
-ACD OEM power steering pump
-TSP shorty manifolds
Sorry for the long winded read, but wanted to get some suggestions from the fine folks on this forum.
