AFM FOR MY 2015 Yukon Denali
AWSMBLU
So far so good no issues.
B-train
Nice! I've had good luck with mine for 4 years and 95k so far.
J5races
I have a cheap jungle site knock off I was using on my 2018 before the Whipple tune was loaded. If anyone needs it do me. Just cover shipping and you can have it. It cost $99
momofx
Say what lol
I've used the Diablosport i3 on mine. So far so good! Some people will say oh it can still mess up and you HAVE TO do the actual conversion with lifters, cam, valley plate etc. I spoke to a few tuners and they said not one they did via tuning has ever come back with the AFM issue.
SpyShops212
I want it
CMoore711
You will hear many different experiences from different owners.
Is it electrical or mechanical?
The PCM is set up or "tuned" from the factory settings to allow the AFM system to function based a certain set of parameters and inputs experienced while driving to allow the PCM to decide when its ok to run on less than all 8 cylinders, then shutting down half of them and going into 4 cylinder mode to increase gas mileage. Have there been any owners you've heard of saying "Man somethings wrong with my AFM system; It always stays in V8 mode and never goes into 4 cylinder mode?" (or visa versa). How many owners are going to the dealership service department reporting issues of the AFM system not activating or functioning? None that I am aware of... Hell I bet over 60% of the owners don't even know it's happening and just drive around. The point is; Electronically the system works and functions as it should.
What is the weakness and failure of the AFM system? Every failure is always related to the AFM lifters and the VLOM which are both mechanical parts in the engine.
Simply deactivating the AFM system electronically via a tune or Range type device is not a long-term permanent solution. Is it better than doing nothing? Yes. For some owners maybe it is all that is needed, and for other's it's not. Not everyone own's their vehicles for 100K+ miles. There are other variables too such as oil change intervals and driving habits that can contribute to varying individual experiences. It really is a dice roll.
My personal experience in my '15 Yukon XL Denali with 6.2 L86 and 8 speed transmission:
Purchased CPO with 24K miles
Installed Range AFM dissabler device at 32K miles.
Oil changed every 3-4K miles with Mobile 1 or Amsoil Signature.
Had a failed AFM lifter at 78K miles.
MrMonte
Turned off AFM on my 2018 Yukon 6.2L 10 speed 30K miles ago & at 87K so far. Mobil 1 oil changes every 5K.
My Son's 2015 Yukon 6.2L 6 speed had AFM failure at 110K which is not a cheap fix.
I get better mileage with AFM turned off than when it was turned on. Last 400+ mile road trip I avg 25.9mpg which in pretty normal +/- 2mpg. Last 30K with AFM off I'm at 20.2mpg with a fair amount of running idle in there.
jaxscuby
Jacksonville, FL
The last 400+ mile trip..with AFM off?
MrMonte
Correct, AFM has been turned off for the last 33,000 miles. My drive to work is about 25 miles each way & 27ish typical if I don't hit many red lights.
I've driven 2,000 miles since the AFM cam delete & very impressed with the results. With 2x daily remote starts due to frozen windshield & many running idle to pop into a store while my wife enjoys the heated seats I'm running around 22mpg Avg @ 30mph up from 20.3mpg @ 37mph. If I get some hwy miles that overall avg will go back up.
jaxscuby
Jacksonville, FL
and you swapped out cams & lifters?
what was the delta in gas mileage for AFM delete and then with cams & lifters?
MrMonte
With just AFM turned off with a tune my mpg increased by .2mpg based on 30,000 average for each.
With non AFM cam & lifters swap after 2,000 miles my mpg increase by 2+mpg. I have several 100+mph burst with 1 reaching the 140 mph speedometer limit easily with power to spare.
The extra power is felt at all rpms, idle is smooth, peddle response is quick. Barely have to press on the peddle & the speed increases which may help explain the better mpg.
I am a quick to driving speed & rarely use my brakes so much mpg tends to be better than most.
Here's my AFM failure/cam swap journey. https://www.tahoeyukonforum.com/threads/afm-lifter-fail-on-my-2018-yukon-denali.143805/
Campie
Oh! I want it if you still have it!?
Buford bubba
