Misfire on number 8
Mudsport96
Mudsport96
40.923,-89.488. Illinois
Yes only code and i haven't done plugs and wires since I bought it. It had i believe 116k on it when i got it but dont remember for sure. It is probably time for them, as i dont know if they were done prior to me buying it. And I am pretty sure it isn't just a miss, it feels like a completely dead hole.
After this cup of coffee I will head out and start pulling the plugs. Wish me luck.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Had 116k miles when bought, how many miles now?
Pull ALL plugs and do a compression test on ALL cylinders. Post pics of ALL plugs in cylinder order. A dead whole feel? A bad plug can have a "no fire" condition and therefore the hole is dead.
Mudsport96
Mudsport96
145k now. Plugs all gapped at spec so the dealership must have done a full tune up before i got it.
Dead hole is what the guys and i called a cylinder that wasn't just misfiring once and a while. It was "dead" as in every rotation it did not fire.
I found the culprit and will update
Mudsport96
Mudsport96
Ok short version
Dead coil on cylinder 8.
Long version,
Check spark = no spark
I have a custom spark tester i made up out of an old sparkplug soldered to 3 feet of 12ga wire with an alligator clip on the end. That way I can stick it in a plug wire and clip it on the negative terminal to check spark.
Pull wire off of 4 and put on 8 coil... still no spark.
Move 4 coil to 8= spark
8 coil = dead.
Raid the parts bin and found a junkyard coil, hook up.... spark!
Backroads full throttle passes to clear plugs and clean cats.
All good now.
Mudsport96
Mudsport96
Just for reference
justinakay79
