Something new to l-u-s-t after
willinnashville
Nashville
**** QUICK DISCLAIMER **** I'm a bit bored at work today.
I went down a rabbit hole today of instrument clusters. Until today I thought they were mostly the same except for stuff like trans temp gauges and cool fonts/chrome trim on Esky clusters. I was on FB looking at posts of a local cluster rebuilder's work when I noticed something I hadn't seen before, so I did some quick FB marketplace research and ran across something new that I really want (which is getting to be a pretty long list).
Did anyone else know that the 2006 clusters have a different P-R-N-D-3-2-1 indicator? My 2005 Denali has the robot LED font separate display for the gear indicator. I really like the 06-only indicator that isn't the separate LED display, and now I want one. That single light under the P R N D 3 2 1 is the hotness, in my humble opinion. I wonder if you could change that color from amber to something else...
I also noticed the 03 clusters are black and not the silvery color that's on the console and HVAC panel of the 05-06 Denalis. When looking through the Escalade vs Denali vs Tahoe thread, I also noticed that the earlier Denali clusters had the odometer and P-R-N-D--3-2-1 LED displays in a single double height spot instead of two separate spots like on the 03-05 versions.
The following cluster pics are not mine, but are different years of Denali clusters. I'll label the year they came from:
2003 Yukon Denali instrument cluster pics:
2005 Yukon Denali (my year, but not my truck) instrument cluster:
And finally, the new object of my desires - the 2006 Yukon/Sierra Denali instrument cluster:
TollKeeper
Brighton, CO
2006 Seems to be a break year for a lot of tech. My 2004 Envoy has a similar cluster to the 1st one. But my 2006 Saab has the underlined one of the later generation.
It was supposed to be 2005 as a general roll out for GM. But they had parts left over. So they used them, until they ran out.
willinnashville
willinnashville
Nashville
So what makes you like this one so much more? We have one in my daughter's 2005 Suburban 1500, and I have one in my 2006 Silverado 2500HD parts truck; so I could transplant it into my truck.
I think the amber indicator looks much cleaner, a lot less clunky
willinnashville
willinnashville
Nashville
Depending on the cluster feels on any given day, I just count how many notches I move the lever...
1 Down for reverse
2 more down to Drive
3 back up to Park
I don't even look anymore... Kind of like shifting a manual! LOL
That's what I'm doing now, my PRND321 doesn't illuminate - solder joints broken, from what I've read.
Without getting all philosophical, I think what makes cars look old and worn out is when you don't fix the little things that break. I've let a lot of stuff go on my Denali over the years that I'm just now starting to fix. Maybe I'll start a YouTube channel or something. Fixing stuff on these is pretty fun to do
willinnashville
willinnashville
Nashville
I forgot all about the GM Saab era. My dad has an 04 Envoy, I should check to see what his looks like
willinnashville
willinnashville
Nashville
Huh - I guess I've never posted pictures. Maybe I should do a build thread. Anyway, this is a couple months ago after I repainted the hood and roof in my garage and swapped to an Escalade rack. It looks tons better than before, but it still needs quite a bit
Electrician
I agree. The 2006 clusters PRND123 indicator being incorporated into the overlay looks cleaner compared to the VFD display on the 03-05. I was wondering what a 2006 overlay would look like on a 03-05. I've never had an 06 to mess with so I don't know how GM engineered the backlights for the PRND123 indicators, but... I'm sure there is a way to modify a 03-05 cluster to make it work. With color changing LEDs to match the rest of the lighting... I think I just added another project to my list. For later
Electrician
That looks pretty nice. Giving me ideas... The 05 Z71 Tahoe I recently bought for $500 came w.o. the roof rack (idk why). So I was gonna get another Z71 rack from a parts yard, but...
willinnashville
willinnashville
Nashville
Thanks man! I think it depends on the direction you're going with your build. If you're gonna lift it or shoot for an offroad look, the Z71 rack looks great and I'd say it works way better with the roller in the rear. If you're shooting for a look that's gonna stay on the street, I would lean toward the esky rack or even shave the rack
Logan5
Albany, NY
When I got the chance to grab an 06 cluster I took it, and I did it for exactly this reason. I hate the lcd prndl display, the clean LED indicators are much nicer.
Those leds are integrated into the pcb, so changing them out for a different color is not simple, like changing out gauge bulbs.
willinnashville
willinnashville
Nashville
It might not be easy, but that sure does look awesome
scottd
