Stabilitrak and Reduced Engine Power in 2013 Tahoe
herbert77060
My 2013 Tahoe stopped in an extended drive-thru line and in backed up traffic. The Stabilitrak Indicator came on and said Stabilitrak Off. The engine was running and in gear but the vehicle would not move. I turned off the vehicle and let it sit for a while (to the chagrin of those behind me) and then started it back up and it drove fine. Please help me figure out what is happening. This has happened twice within the last 30 days.
I also noticed the battery/voltage indicator was registering below what it should have been the second time it happened. The battery/voltage indicator dropped this morning while driving normally.
Thank you for any help.
Geotrash
Dave
Richmond, VA
Possibly the symptoms of a bad ground or a bad (internally corroded) battery cable. Search this site for "big 3 upgrade" for more info. How old is the battery?
H
herbert77060
I am not certain how ol the battery is. i purchased the Tahoe in October of 2022.. I was thinking about heading to an auto parts store and have them check it for me. Thank you for your reply.
Geotrash
Dave
Richmond, VA
A bad cell in a battery can cause all kinds of weirdness in these trucks along the lines of what you're describing, as can weak/corroded grounds and battery cables. Good luck!
Take the battery to a local parts store with a bench battery load tester (battery comes out for the test).
H
herbert77060
So far so good guys since i replaced the battery. I have not had a situation where I had to sit in a line and idle for a long period yet.
H
herbert77060
Well guys it appears the problem is the Powertrain Control Module. The code is P0601. I went to two different places for the to scan and the report was the same.
intheburbs
SE MI
Voltage swings wreak havoc with the electronics. Replacing the battery helped, but if it was my truck, I'd be checking the alternator and battery again. I'd say a bad alternator is more likely than a problem with the PCM chip.
H
herbert77060
I had the battery and alternator checked by two different places (one being my mechanic) and they both said the alternator was fine.
Geotrash
Dave
Richmond, VA
Uh huh. Unless their tester checks for ripple currents, which most don't, you can take their opinion with a grain of salt.
HeavyHoe03
