a/c o-rings
dougmorgan7435
Does my 2003 GMC Yukon Denali XL have o-rings or metal/blk rubber washers on the A/C hose fittings? I don't trust that it was correct when I started . Just replaced Compressor, Accumulator and Orifice tube. So I opened the system in 6 places ; and after evacuation , it does not hold pressure. Some fittings had round o-rings , some had flat washers but some had both. thanks
Multnomah Falls
Military
Welcome to the forum.
You can use a kit like this: https://www.rockauto.com/en/moreinfo.php?pk=9160640&cc=1415573&pt=13290&jsn=1650
Whatever was there when you took it apart, should be used for replacement and never reuse a seal. You should have lubed the new replacement seals with a/c oil when installed. Not holding pressure/vacuum means you have a leak and you need to recheck your work. Have you done a/c work before?
rockola1971
Indiana (formerly IL)
Have rear a/c? Sure your leak isnt back there? Not uncomon for front evaporator to get a leak. Oring kit is cheap. Did you wet orings/washer with lube oil when you installed them or did you install them dry?
D
dougmorgan7435
Thanks for the advice, It turns out that with age the factory metal seals w o rings made together will separate appearing as two distinct parts. I went ahead and got the seals at the dealer , mostly to make darn sure I had it right. The Loaner gauges needed a xtra bit of muscle to close completely . Now it recirculates 44 degree air . Thanks all.
When our system was opened up, some of the o-rings and seals/gaskets were replaced by parts from O'Reilly's and they leaked. Like you, we then got GM parts and the system then became perfectly sealed up!
rockola1971
Where did you run into a metal gasket without orings?
Pepper1700
