GMT900 front brake upgrade for my GMT821 ... what ELSE do I need?
Marky Dissod
Unless convinced otherwise, GMTK2xx or GMTT1xx front brake upgrades seem like diminishing returns vs GMT900.
Drove a 2012 Yukon XL for 5 years as a livery vehicle in NY / NJ / CT / PA, assertively if not quite enthusiastically.
Carefully chosen front brake pads kept me from investing in any brake upgrades on the lease that I turned in in 2018.
Without a more 9C1/Z56/PPV type suspension, GMT900 front brakes and well chosen pads should be enough for me.
I understand that I need
Rotor discs
Calipers
Pads
from a 2010 GMT900 vehicle to upgrade my front brake system.
Besides the above, is there anything ELSE needed to complete the upgrade?
Answer: 2010 Caliper Brackets
M
Marky Dissod
Separate but related: can I upgrade the master cylinder, or anything along those lines?
I'm aware of braided stainless steel brake hoses.
I'll upgrade those if the GMT900 front brake kit and a better master cylinder (or something like that) isn't quite enough.
Sam Harris
I’d go ahead and do those stainless lines while you’re at it. $0.02
M
Marky Dissod
Frankly more concerned with upgrading master cylinder / booster / proportioning valve / metering valve / stuff along those lines.
Mine are 21 years old, after all.
If I can afford it - tight budget, might source caliper brackets from junkyard? - I'll buy braided stainless lines.
Sam Harris
Nothing wrong with junkyard calipers & brackets if they’re in decent shape. And I believe there’s a rebuild kit if they need it.
M
Marky Dissod
No need for any upgraded master cylinder
In the sense that I do not NEED to upgrade the front brake kit from GMT800 to GMT900, I can easily agree.
However I was under the impression that there was an OE-type GMT800 or GMT900 master cylinder that was directly compatible with my goals.
Can't remember if it was from an Escalade, or a Z56 / 5W4?
mattbta
Frisco, TX
If you've got Hydroboost, seals in that are known to go out. There's a rebuild kit or you can get a reman unit.
Sam Harris
I don’t have hydroboost (unfortunately), and the conversion is a bit of a PITA, though not too bad. But after the GMT900 upgrade up front, stainless lines in all 5 locations, and the Powerstop Z36 on all four corners, it’s a dramatic improvement! If I had the hydroboost as well, that would be some serious braking force.
Anyway. As far as I’m concerned, the GMT900 upgrade, combined with stainless lines, and good rotors & pads is more than adequate.
jmart157
