Which Fuel Tank do I need? 2011 Tahoe LTZ 4x4 5.3
rbarker31
Hello,
I may need to replace the fuel tank (26 gallon) on my wife's 2011 Tahoe LTZ 5.3 4x4 and am unsure what tank is needed. When searching online I find two GM part numbers and the prices are drastically different.
Part Number: 84200270 - https://parts.motorcitywest.com/oem-parts/gm-fuel-tank-84200270
Part Number: 25920048 - https://parts.motorcitywest.com/oem...haG9lJnk9MjAxMSZ0PWx0eiZlPTUtM2wtdjgtZmxleA==
Can anyone shed some light on the difference between the two?
Any help is greatly appreciated.
Thank you,
Robert
Hello,
Part Number: 25920048 - https://parts.motorcitywest.com/oem-parts/gm-fuel-tank-25920048?c=Zz1mdWVsLXN5c3RlbSZzPWZ1ZWwtc3lzdGVtLWNvbXBvbmVudHMmbD0xOSZuPUFzc2VtYmxpZXMgUGFnZSZhPWNoZXZyb2xldCZvPXRhaG9lJnk9MjAxMSZ0PWx0eiZlPTUtM2wtdjgtZmxleA==
Thank you,
Robert
I come up with the first number. Give Rene the last 8 of your VIN to be sure. @915_Tahoe
R
rbarker31
Thank you!
The problem was the fuel tank wouldn't accept gas. When trying fill up, the nozzel would just click repeatedly unless you filled up at a snails pace which took close 30min.
It turns out I don't need the tank as it was the charcole canister from the EVAP system that decenagrated and clogged all the lines. They were able to replace the canister, flush the lines, and clean the tank. Now all is well again!
Thank you everyone for the assistance!
Geotrash
Dave
Richmond, VA
Thank you!
Thanks for following up. It’s a common problem, and there are lots of threads here on it. Its a good idea to replace that charcoal canister every 10 years as a preventative maintenance item.
repairman54
NW NJ
When filling up do not try to get every last drop of gas into the tank. Just round off to the next dollar when pump clicks off and leave it. Overfilling forces gas into the charcoal canister and kills them.
Of course if you bought used you have no idea what the previous owner did.
stocksj
Brandon, FL
I have a similar issue with my used 07 Suburban. The return air vent line is clogged and don't allow air to vent when fueling at the pump. I need to replace my canister also but until then you can refuel by using 5 gallon cans and doing a manual pour which works out. It's just a PITA doing it that way.
vtxtexan
