DuraYuk
- Joined
- Sep 17, 2022
- Posts
- 809
- Reaction score
- 578
Dry sump is totally different lol. My maserati is the same.Even if you were down to 4 quarts it should of had oil pressure. Unless chevy put the oil pickup location like 3 inches from the bottom of the pan. My Gallardo holds 10.5 quarts and the fill procedure is to put in 5 quarts and start in then add the rest, yes dry sump but still you should have had pressure.
I wouldn't want to put 1/2 capacity in a traditional oiling system before start up. You will cavitate the pump and won't have enough lubrication or pressure.
