My Project Tahoe
Thanks so much for the link. The price of just those springs is the total price of my Crown kit with the drop spindles...lol Would like to get them and try them out. But what to do with the other ones. Plus I have my air bag system in the springs. Be a challenge to get them out out of the springs.
It’s called metal recycling lol- those Crown springs aren’t worth much but you might be able to sell them here in the classifieds after you get enough posts. Looks like you’re almost there. And the bags come out just like they went in- deflated. Sounds like you’re going to settle with what you’ve got though. Good luck, hope it works out for you. There’s a few things I wouldn’t try to go cheap on, steering and suspension are two of them. I need my big old SUV to handle and stop as good as it can. It can be dangerous in the wrong situation where I need it to respond fast if it doesn’t.
DadsToy
DadsToy
South Carolina
I will agree with you on the safety on the steering and suspension. I want it to perform and drive safe. I notice the Belltech springs are coiled in the right way. Where the coils on the bottom are tighter together than the top. That would eliminate the bounce. The Crown springs are not designed that way and are straight coils. As far as removing the air bags from the springs. I am going to try a little trick . Going to soak them in warm water. That will soften the bag just enough so I can bend them out of the spring. It was really tough getting them in. And of course deflate them just like I installed them. I like the bags and do help out with towing heavy loads so far. So hope I can save them.
Maybe add dish soap to the warm water so they slip out easier? Anytime I’m trying to get rubber parts on or off I use Dawn and it works pretty good.
DadsToy
DadsToy
South Carolina
Its been awhile and have been driving the Tahoe some more. Seems things are settling into place. Wanted to make sure I was right about things before throwing more parts at her. The death wobble is gone. The shocks cured it. The only issue is the slop in the steering wheel. I am pretty sure its the steering gear box is worn out. Tried adjusting it. Seemed to help some. But I believe the worm gear is to far gone and won't adjust... Time to shop for a new one.
In the mean time was able to get heat back into the car. The Mode Door Actuator had a broken gear and cause the baffle doors not to move. Was able to source one from Amazon for $18. If you replace one of these. Make sure you buy the one with the metal shaft. Man what a pain in the neck to replace. Easy part is pulling the old one out. Hard part is putting the new one in. Trick is to install the gear first then the motor. Also note; after you install the new motor, DON'T connect the wire connector to the actuator. First turn on the air and see where the air is blowing in from. Mine was set for the floor. After you found out where its blowing from turn the key to off. Then set your selector switch to where its blowing out of. Like mine the floor. Then plug in the power connector in. This way the actuator will be timed in the right spot.
This job was a challenge for me. You see.... I have Glaucoma and its very hard to see up in those tight spaces. And bifocal lens don't help matters either. Plus I have no disk in parts of my spine. All from injuries from being in the Marine Corps. You know, blown up, shot up, gone down twice in the helo, fell out on one; that's another story. So this build in a way is my therapy car. Keeps me moving. Just hoping I can get it done before my eyes give out and things go dark on me.
Here some pictures in hopes it might help someone that might be doing a Mode Door replacement. Cheers.
Old part with part number. Use this to search for a replacement.
New part. Note metal center shaft.
Old part with broken gear. Might see if I can J/B weld it back and keep it as a spare part. You never know...
This is the gear mounted back into place. Must do this first, then install the motor. After installing made sure it move freely to insure the baffle doors operator right. I cleaned the old grease off and used new lithium white grease. It helps to remove the one screw holding the lower duct and push it to the passenger side of the car. Adds just a little more room to work. This actuator is located on the drivers side next to the accelerator pedal. Now that is done. Time to take drugs...My neck and back is killing me.
DadsToy
DadsToy
South Carolina
Haven't been able to do a whole lot of work on the Hoe. With Holidays and the cold weather setting in. So just finish installing the tow brake assist. Was the easiest project I had to do yet. Seems the car is already wired. All I had to do was plug in the adapter wire kit and plug into the module. Done. This is located on the left drivers kick panel. Have to remove the plastic cover to get access to the panel.
Red arrow shows where to plug in the Wire kit.
Used super strong velco instead of screwing it to the center console. Location works prefect. In reach and plan sight. I can still use the power outlets behind it.
DadsToy
DadsToy
South Carolina
Another easy project was to replace all the interior lights to LED bulbs. What an improvement over the stock bulbs. Oh and let me tell you. The back cargo light bulbs get really HOT. Went to remove it with my fingers and burnt the crud out of them. Had to use pliers to pull them out. Much brighter and uses less energy. Even did the glove box light too. Took some night shots which were taken without a flash. I just need to replace the outside marker lights and upgrade the headlights next.
DadsToy
DadsToy
South Carolina
I wasn't going to originally fix this issue. But it came down to a safety issue. I couldn't get the washer fluid pump to work. I replaced the tank and pump (PPL $11) thinking that was the issue. The old tank was pretty trash from battery acid etc.... Still wouldn't work. By accident I got it to work. You have to turn the left turn signal on and then push the washer leveler forward. Pump work. Crazy. Thought i would just leave it. But what if someone else drove it. OR people behind me see my left signal come on thinking I am going to turn and I am not. Just cleaning my windshield. So amazon supplied me with a new multi-function switch, $42. Took me a couple of hours to replace it. Had to remove the lower kick panel. Then the crash shield, just to gain access to the multi wire connection on the column. Two of the connections where pretty tricky to get to. Problem fix with the new one installed. Everything works and the turn signal is solid. NO sloppy controls. And it looks great like a new car.
This is what I am was working on. The old switch with the covers removed. The covers just pop off. You have to pull the tilt lever out first.
Have to remove the safety shield first to gain access to the connectors. There are 4 bolts (red circles) you have to remove. The left green arrow is the multi wire connection. Have to unbolt it. Its the only way these come out. Best to disconnect the battery before doing this. The right green arrow is a connection you have to remove. Very hard to get to.There is a safety lock you have to remove, then the connector will come out.
New switch installed. There are only 2 -25trox bit screws that you have to remove. One at the top and one on the bottom front. Hardest part is getting the wiring removed and putting all the plastic stuff back. Another back crawling, finger cramping project. Now everything works like it is suppose to.
Thanks for the write up on this. I keep thinking one day I’ll have to replace mine on my 02 and I go have a look at an OEM one only to see it’s $300 and I once again decide if it ain’t broke…I usually replace items for preventive maintenance but sometimes the part is too expensive so I don’t. It’s good to see it’s not that hard to do- it gives me options in my mind if I would possibly go with an aftermarket one.
DadsToy
DadsToy
South Carolina
I am the same way. That's why I really wasn't going to do the project. Cause in a way it was working. Thought it was going to cost a lot. But for less than $50 for an aftermarket one isn't bad. I spend more eating out than the cost of that part. Which brings me to my next quest. The power steering gear box. Been debating on whether to buy a manufacturer unit or pull one at the PPL. New it cost over $600, reman cost around $300. Going to the PPL cost is $80. Thought is to pull one for $80 see if the problem is fix. Then a little later to install a new unit after the elections.
If you do this mulit-function switch. Have patients. I was at a point where I wanted it just done and I couldn't reach or get to the connectors. Lucky me I have surgical tools that help reach back to the connectors. I used to work as a Bio Medical engineer. So got the old surgical scissors etc. that they through away. Easier way would have been splicing the wires. Which I am against that kind of work. Would have been another point of failure.
DadsToy
DadsToy
South Carolina
After replacing the Mode air motor. I wasn't happy with the amount of air coming from the vent. So I investigated the blend door motor to make sure it was working correctly. Works...So in doing so I discovered the cabin air filter box. Thought I would change it. Let's just say it might be the original one. So you all might want to take a look at yours if it been over a year since you replace it.
There are 2 of them in that box. The new one I order from Amazon came with 2 to a set. Much improvement in air flow.
All the stuff that fell out. Also had to vacuum the box out.
DadsToy
DadsToy
South Carolina
Santa brought me this light. Has bluetooth speakers built into the lights. The lights have about 4 different settings. Also an emergency red flashing light. The lights can be removed via magnet mount. Rechargeable USB battery. I link it to my phone and play pandora. The sound is awesome. Now I can work almost hands free without fighting for a light.
DadsToy
DadsToy
South Carolina
Well you all have given me the encouragement to carry on. Thanks. I thought I would try one more time at the steering issue I had on hand. The sloppy play in the wheel. The Junk Yard route was a bad idea. From now on. Unless I need a part on hand like right now. I don't think I'll be doing major parts from the PPL. Only plastic interior parts.
So I broke down and purchase a remain Steering Greer Box unit from Oriely's. I have to share this. I order it on Thursday and got it Friday morning!! I order it online and it had a 20% discount code at the top for home delivery. How can I go wrong...type in the code and yep got 20% off. I wasn't believing the next day delivery. But sure enough. BY 9am it was setting on my front porch. Oh and free delivery!! The whole unit was only $20 more then the PPL unit that was a piece of crap.
I took your advise and took my time. I even turned the shop stereo off. Just relax, thought about it and just got it done. Took me a little long than I thought it would. But it feels great that I fix it and I saved over $1500.
I will tell you this. If you should ever do this project. Make sure you get the replacement shaft nut and a new Pittman arm. That arm will not come off. I had to remove it from the old unit before turning it in for the core. That ever happen. I cut on it, heated it and even used the puller tool. Must have beat on it for an hour. It will not come off. Even the one from the PPL wouldn't come off. So thankfully I had ordered a new Pittman arm. I also replaced the Idler bracket and arm. So the whole front end is all new.
Man it made a huge difference. It steers so easy now. The play in the wheel is gone. It used to drift from side to side and was hard to handle on the road. I am so glad that is fix. I flush the power steering pump before running the new unit. If you haven't done a flush on your power steering fluid. You need to. I am also going to add a inline filter.
Now it time for a shot of Rum and Tylenol.
Old unit, New unit.
New idler. The old fluid. Was dark and burnt. This is supposed to be clear.
So while I was under the car. I spent about 30 minutes or more scraping the crud off the front of the engine. I have a bad front crank seal leaking. This was all over the timing cover. There is still a lot more on there. I'll get to it when I replace the cam and top engine rebuild.
DadsToy
DadsToy
South Carolina
I actually thought this was the rum until I read the details... :jester:
LOL.....But I am feeling every bit of it today.
That steering box is heavy. The steering wheel is about a 1/4 off. I knew going into this project I might have an issue with the steering wheel being off. So going to drive it a bit and let things settle in. If it goes down the road straight and the alignment is in check. I might have to move the steering wheel to get it straight again. But you never know when you mess with the steering components. Things might got out of wack. Then it will be another trip to the alignment shop. I used to do it myself. But for $70 bucks its worth my time to let someone else do it. Cheers...to overcoming and achieving successful project fix. Whats next? Oil leaks, engine rebuild, Brake rebuild/upfit, or replacing the rear springs to something different.
Caddylack
I feel obligated to say this:
Acetaminophen (Tylenol) is one of the biggest "no-nos" to combine with alcohol. It's extremely toxic to the liver.
Any other pain killer would be better.
My friend's dad died in his late 30s from liver failure, and the doctors said it was because he had a habit of combining alcohol and Tylenol. Nobody ever told him it was dangerous.
DadsToy
DadsToy
South Carolina
Life is getting in the way of this project. I finally went and have the car aligned again. So its straighten out. Steering play is gone and drives great. Easy to steering and don't have the death wobble any more. That steering box was wasted. Just used it to tow a small camper and did really well. But going up hill it struggle a little. I think a turbo would help with that:driver:
DadsToy
DadsToy
South Carolina
Oh no, I have the lifter tick. At first thought it was an exhaust leak. When you first start it up you can hear it. Then about a minute later it goes away. Only does it on a cold start. Oil pressure is good. I even tried oil additives to see if that would help. So looking at cam swap, lifters, rockers, push rods etc. Will have to pull the heads. That is the part that sucks. Wish there was a way to replace the lifters without removing the heads. So out scouring for a complete cam kit on ebay that has all the gaskets, cam and other hardware. I think I'll be all in for around $668. Use a sloppy stage 2 cam kit. But other than the cold start tick. Engine starts and runs like a top. The only other issue I am pondering is to replace the oil pump and timing chain/ gears. Have to drop the oil pan to get to the bolts for the pump. Wonder how hard that is going to be to drop the pan. Seems like more work that isn't needed.
Geotrash
Dave
Richmond, VA
Bummer about the tick. As long as it's only at startup, you likely have some time left but new lifters are in your future, and with that mileage I agree that a valvetrain refresh seems a good idea. Dropping the pan is more hassle than I like, but after doing it 3x now, I can do it in an hour or so. A new oil pump is a good idea, if for no other reason than to have a fresh o-ring on the pickup tube.
Sloppy Mechanic Stage 2 kit like this one?
Those cam specs aren't optimized for a truck that will see towing duty and will also give you pretty good idle chop. For towing, I would want a smooth idle and cam specs optimized for low to midrange power. Of course that may not be what you want, and that's okay too. I just found a lopey idle to be uncomfortable at traffic lights when I had my Yukon set up that way. I ended up getting a stage 2 truck cam from Cam Motion and I love it.
Whatever you do, use only genuine GM lifter trays. I had 2 cam failures in a row thanks to cheap aftermarket trays letting the lifters twist in their bores.
j_jerry79
