Rear defroster not working
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I’m not one to do half assed repairs but hear me out.
What if you de-pin the four bad pins from connectors and then plug them back together. Then, run a pair of wires though the spaces in the connectors and solder/heatshrink them. You can force some RTV throught the connector and be on your way. You may never need to touch that connector again.
Just tossing it out there.
MacGuyver / A-Team schit gitt'r done and do it better!!!
SnowDrifter
SnowDrifter
Sasquatch Country
Actually
I don't hate that
Though, I might subsitute some butyl for RTV - reversible and whatnot (butyl and dielectric grease are my usual weapons of choice). Or just toss a higher power connector in there to take the 30 amps that the defrost pulls. I already have the connector kinda drilled out for routing a dash cam wire. Or hell.... Even soldering it wouldn't be terrible - still can be disconnected because the grommeted bit is just a tiny little harness based on what fless and yourself found - can still be disconnected from the hatch side
Need to see how much extra wire I have to work with on the body side. That might be a task for when it's not in the teens and freezing rain
BeenChevy
Minnesota
Exact same problem on my hoe a few years back. Noticed the defrost quit for days after washing it. Pulled apart the harness and bingo. Used a 12-pin waterproof connector kit laying around from another project and it worked perfect. Was probably $5 on scamazon.
Released all the pins from the existing harnesses and snipped/stripped immediately after the pins and there was still just enough slack to go back together perfect.
SnowDrifter
SnowDrifter
Sasquatch Country
Oh nice
Happen to have a link by chance?
AdrienR
