Air box snorkel
Thrust
ICT
Does anyone have the end of their airbox with the snorkel?
Mine on my 2015 detaches. Let me know and throw me a price.
Thanks
BlaineBug
Clown World
I see. I know this is unrelated but the stock airbox flows PLENTY. A lot of these "cold air intake kits" are a bunch of hype, some are even WORSE than factory in regards to drawing in hotter air than OEM. Also the "huge" OEM intake silencer box between the radiator and throttle body doesn't limit flow at all, there's no real reason to replace it with a "tube" unless you don't like that large box obstructing the motor.
Thrust
Thrust
ICT
So what's the mass flow of the snorkel when you add a 2.3L Magnuson on the 6.2L?
I appreciate you trying to educate me but my Yukon is not stock.
ThanksView attachment 387770
It looks similar enough to my '08. Could you do something like this?
and
Gigantic hole and super tight seal for cheap! You'd lose the snorkel. But, I don't know how critical that even is when SC'ed.
Thrust
Thrust
ICT
I did something similar, and also enlarged the fender cutout to match. Looks alot like what you have.
I definitely like the seal you went with. Thanks for the info.
BlaineBug
Clown World
That foam is factory at least for the 2015-2020 crowd.
brice715
