Foot-Well wiring , need help finding the correct wire.
rdhogg
Houston
I have a 2013 Tahoe and trying to determine what color of wire I need to tap into so the footwell lights come on with the instrument / switch back lights. All the wire diagrams i found you have to pay for, there has to be a better way to find out. What say you ?
you want them on all the time? or only when you open the door or turn on interior lights?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Also there are some panels behind the parking brake and the drivers side dash. I just don't have the time at the moment to find them. They are posted in here somewhere. Search dash cam wiring posts/threads.
rdhogg
rdhogg
Houston
Thanks, looks like on page 457 under D-279 it shows the back lighting for the interior insterments and switches get power from BN/WH wire, I need to find a good place to access that wire and put a test T-Tap on it and see if it controls the light the way i need. Thanks again for the access to the wiring diagram look-up.
I have mine tapped into the drivers foot kickpanel, the interior lighting wire can be accessed there pretty easy to do
the gmupfitter guide has some good well defined diagrams
just go there and select your year as there have been changes made around 2010
rdhogg
rdhogg
Houston
Thanks, I will get on it
Hodmjstone
