Redhoe01
The BDG
Forney, TX
Cleaned my truck up real nice. Replaced two bad wheel studs from the tards at the shop messing them up. I changed the oil and switched from Castrol High Mileage to Mobil 1 with filter. Scored a good deal at Autozone Mobil 1filter and 5.28 quart big bottle of Mobil 1 for $29.95 Dropped it off at the mechanics for the A/c and Water pump to get done. Oh and removed the Tahoe and Cheverolet from the back lift gate.
Tahoewhat
Ballin' on a Budget
TX
Washed and Cleaned it up For it to rain the rest of the week. :emotions122:
Stockfornow
Spencerport, NY
based on what you can find here, you can slap a 4" filter (K&N, etc., anything at your local parts store) right on the MAF where the airbox used to be. This is probably the easiest way to build an open element short ram intake. Pros: super easy, cheap, no water danger, sounds good at WOT, better throttle response. Cons: potentially sucks in warm air, so by itself isn't going to help your peak HP numbers or anything, if you get a filter that needs oil, it could kill your MAF, get a dryflow
A step further might be an ebay intake for around $100 that puts a silicon elbow on the throttle body and has a large diameter straight tube with MAF adapter. These are still usually SRI style, not CAI style into the fender, but they are a straight smooth, large diameter tube and replace the weird stock plastic baffling under the hood. Pros: better than a filter on the MAF, still cheap. Cons: warm air problem again, and if you go ebay, make sure the filter is legit, or it can mess you up.
Final and WORST option: take your wallet, shove it up nethers, crap out a bunch of money, and buy a name brand "intake" and have a "professional" install it. You can replicate/improve-upon pretty much any intake design for under $100 if you work smart.
IMHO the best solution is some sort of ebay/homebrew combo, perhaps ebay tubing with a good filter in the engine bay with some sort of heatsheild (I've heard mini-kegs work great . . .). I would never recommend paying the ridiculous ticket price for the major brand intake systems. A pipe is a pipe is a pipe I say, do it yourself!
Picked up a section of 3" straight PVC pipe, a 90 degree elbow, a 45 degree elbow and some couplers at Lowes. Under $40 dollars. Hopefully this will work!
Is the 3" too small?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
Cool man... you did put the 6th quart in, right? :)
Eagle
EL PASO, TX
IIRc I used quite a bit of my 6th quart if not all. I cranked it and shut it off to fill the filter before I measured with the dipstick.
Max
Mile High
Denver
Capacity on these trucks is just a hair over 6 quarts iirc, I just use every bit of 6qt royal purple.
Brick
Boca Raton, FL
installed blue leds behind the gauges and removed stock cassette player-fabricating a piece to hold some switches and bass controllers to fit in its place
Eagle
EL PASO, TX
Took an iphone pic of me using it as a ladder:
ie I climbed out the open sunroof and walked right onto the roof. Can't believe it took me 6 months to think of it.
Besides it was a good excuse to show off the wheels with everything clean.
oak510_tahoe
Urban Assault
well it was 2 days ago, installed a laptop mount. Long road trips no problem now.
hassoun
Germantown, MD
oak510_tahoe, got a picture of your mount ? i have my eeepc 901 mounted as well but interested in seeing yours ?
Cobra
Austin, Tx. area
My Tahoe made an Expedition owner look stupid when he tried toying with me and I left him as a reflection in the rear view!
Merch619
