Tech2 and SPS2 programing
Fubar0715
Scott
Southern New Hampshire
I am an owner of a Tech2 diagnostic tool and after countless hours of trying to get the unit to serve as a pass through, I began reading and researching why the GM SPS site would not working with the tool. After reading on several sites, including our own, I learned that GM had changed the site and using the Tech2 was no longer on option without contacting GM support. My understanding was the after going through troubleshooting, GM would grant a single day pass to the legacy SPS site.
I began looking for an alternative and found references to using a VCI (MDI Clone) device-such as VXDIAG VCX Nano. I purchase one from Amazon (https://www.amazon.com/dp/B08K2SXY79?psc=1&ref=ppx_yo2ov_dt_b_product_details) which presented a whole new set of challenges with setup. The software that comes with the unit lacks any direction, doesnt seem to work out of the box with what is provided, and kept killing the Techline Connect app. After taking to the web and a lot of trial and error - I was able figure out how to setup the VCX Nano and make it work with the SPS2 website (I can see my Tahoe's systems now)
First thing - download VX manager from here and install - be sure to select GM option (see pic) https://mega.nz/file/udohRDTb#xrt4ui1A2yh0GnOWHPmm2jsAdD7PU3G7vcU2K3tCtYA
Complete the install using the default settings. Before installing the Diag modules - install TLC (version 1.14.0.1 or most current) which is the Techline Connect suite from ACDelco TDS. You must have an account which is $45 per VIN to get into the SPS2 services website. Once the TLC suite is installed, go back to the VX Manager application previously installed and go to the Diagnostics tab (ensure the VCX Nano is connected to your computer via supplied USB cable) and install the following tools.
Once these app have been installed, log back into acdelcotds.com website, add vin, and launch techline connect via webpage. The SPS2 site will now see your VCX Nano as a GM MDI device which allows communication with your vehicle systems. As you can see in the pic below - the device is detected as a J2534 Bosch MDI device.
Hope this show and tell helps others having issues with the Tech2 and the Techline Connect website.
First thing - download VX manager from here and install - be sure to select GM option (see pic) https://mega.nz/file/udohRDTb#xrt4ui1A2yh0GnOWHPmm2jsAdD7PU3G7vcU2K3tCtYAView attachment 377461
Nice work! Our collective knowledge base has been increased.
St. Louis
Is this VCX nano device capable of doing the standalone actions the Tech2 does, or only the pass thru programming?
Fubar0715
Fubar0715
Scott
Looks like pass through (acts as the MDI device) with SPS2 system currently in play from ACDELCOTDS.com Since I kept hearing that Tech2 passthrough was being phased out or issues connecting needing customer support to work, felt we needed a documented process to continue to use the programing site.
the vcx manager must be running in the background for this to work (pretty sure anyway) unless something has changed
St. Louis
So you'll still need both devices? This vcx to do programming and the Tech2 to troubleshoot and read sensors etc?
Fubar0715
Fubar0715
Scott
What I found while testing was the VCX needed to be connected - SPS2 detected the device on my laptop and connected to the truck. I was only using the techline connect-VX manager was not running during the session, FWIW!
So the Tech2 win can do all the Tech2 stuff like enabling afterblow and calibrating the ride height sensors?
supposedly there is a couple things it cannot do versus a actual tech2 but I do not know the details, although I did not or have not tried those 2 particular things I could not find anything that did not work.
Fubar0715
Fubar0715
Scott
If anyone thinks of something that needs tested, please ask. I am going to do some BCM upgrades this evening and additional poking (research) around to familiarize myself.
DJones
Largo, FL
I had major success while using SPS2 and Techline Connect to program my driver door module. Here is what I learned.
Guide I followed: http://blog.vxdiagshop.com/2022/03/...ano-gm-with-techline-connect-vmware-solution/
My particular scenario: Use a VM on my work laptop because my home desktop is everything that is not approved: Fedora 36, Ryzen 7 5000 series, and not portable. The work laptop has a strict security policy, but VMs are approved and there is no security policy for them.
What didn't work: 1) VirtualBox. All sorts of weird errors such as unable to authenticate TDS. I spent 3 hours on this before giving up and moving to VMWare Player. 2) Windows Host: could not download a Windows ISO while already using Windows and can't execute the media creation tool due to the work laptop security policy mentioned above.
What did work: 1) USB passthrough to guest OSes on either VM. Easier to set up in VMWare though. May be useful in the future because I have weird graphics issues with VMWare. (white distorted blocks) 2) VX Manager 1.8.9. I think it is the newest version. 3) Launching from Edge browser. 4) Not installing software in any particular order. 5) Only needing VX Manager and Techline Connect.
Actual process took maybe an hour from start-to-finish, including the Windows 10 Pro install.
The driver door module was programmed in under 5 minutes and resolved all of my weird issues I mentioned in my introduction thread.
Pickensmd
Wow, I read that twice and am having a bit of a hard time replicating your success. If you can make the time, I’d love to learn more.
Mickey_7106
Bay Area
To use Tech2win for diagnostic using the vcx nano, do i need to purchase a tech2win subscription from acdelco website or just the sps2 $45 vin credit?
johnsonwillie199
