Help With Part Number Please
kadrovik
Hello. I have a 2018 Tahoe with the Z95 mag suspension. I want to replace the rear air shock absorber with a shock absorber Nivomat from suspension ZW7. Do such shock absorbers exist? If so, tell me the number?
mb1500
ZW7 in later years is not Nivomat, only certain years NBS I want to say be careful what you purchase might end up with a traditional damper.
If you do not replace with another assisted shock than you will need to purchase new coil springs because the spring rate is too low without the assistance of the air ride.
You will also have to purchase a magneride eliminator kit to remove the error message that comes with removing a Z95 component.
Super Moderator
Elev 5,280
Model years 2000-2006 IIRC
^^ This. They are OE for the Premium Smooth Ride (ZW7/G65) RPO code on some NBS's. No telling if they would work or fit on a later model, if that's what's being asked.
you are better of sticking with the Z95, like noted above if you change it you have to trick the system and change springs and then you probably need airbag 1000 to boot
kadrovik
kadrovik
what is NBS?
I don't like her, she's tough. Showed itself very poorly at low temperatures, often breaks
not a problem
for this, Nivomat is needed, he will do it all himself
what is NBS?
not a problem
NBS is "new body style" and is in reference to the model years 00-06 also known as GMT800
Xay2Smoove
