Sparksalot
Bastrop County, Texas
Decided I didn't like polished wheels after all.
Joeltz
Today and for the last week, at home with only a bottle Jack and a few hours a day I Bolted in a Front Trailer Hitch.
UPSIDE DOWN
Drawtite Should make this !!!
jd08
Jackson, WI
Upgraded the low beam halogen bulbs to vleds extreme bulbs. I also swapped the fog light bulbs to leds.
This was a huge improvement. Last year i went from h11 bulbs to h9 bulbs. That was ok but still wasn't good enough.
Jeff_
Scottsdale, AZ & N. Idaho
Nice! Any pics of output?
Joeltz
UPSIDE DOWN
Got the hitch in upside down & tricky to get at correct height/ angle to come out in the right place !
has anyone swapped a (enhanced cooling) NHT radiator into a non NHT ? a little research tells me the core size is the same but the tank is larger on one side, so wondering if it is still a direct fit or not
Pivot
UPSIDE DOWN
I processed this as "with only a bottle OF Jack" at first, which also would make sense. Nice work!
SpyShops212
Had my lifters replaced in my 2018 Escalade due to a lifter collapsing at 79.9k. The job costed me $3200 which GM paid for 1/2. Ny advice is to use Dexo 1 oil and to get a Range Disabler. My oil pan also had a leak so I had them replace both gaskets and the o-ring
Sparksalot
Was going to rotate the spare into one of the road positions, but got to looking at it. That tire has been on the ground already. Probably swapped out when I changed the wheels a couple of weeks ago.
I doubt the dealership did a 5 tire rotation last week when it was serviced.
LT1ZOB
What is vrt cleaner & how do you apply it to the headlights?
VRT is an Adam’s Polishes product specifically made for porous plastics. I do not use it on headlights. I use the finishing polish then wax on the headlights with a polisher. They come out looking brand new every year.
ASG-MikeS
