Famous Clunk
crownvic31
Hello
I been having the famous clunk when coming to a stop or when launching. I have greased the slip yoke in the pass and it improved the situation for a few days. I would like to fix this for good. I understand there is a nickel plated slip yoke that will resolve this? Any one have a part # for this for my 07 escalade AWD?
Geotrash
Dave
Richmond, VA
Hello
It's more likely that your problem is coming from worn/dried out front diff mounts on that particular vehicle.
Hello
Not supposed to put grease on the slip yoke going into the transfer case as it contaminates the fluid and can clog the pump.
Most times that clunk is because of the driver's side engine mount and next on the list are the mounts for the front differential.
C
crownvic31
And you guys were right! Went out side real quick and got under the escalade. Realized that the driver side bracket has a good amount of play in it. Also realized a small drip of fluid from the passenger side front differential axle. I am guessing that is the seal.
I had the same issue on my 07, and after replacing the slip yoke, and all rear drive shaft universals without resolving the issue, the source of the issue ended up being the front differential mounts. The mounts are comprised of 2 metal arms about 1 foot+ long, and bushings pressed into each end.
C
crownvic31
ok, so picked up the escalade last night from mechanic. Things didn't go as smooth. So when dropping the front diff to replace the brackets, mechanic noticed a diff leak on the end of the diff passenger side which was the seal. So I gave him the ok to replace the bearing and seals on that side as well as on the driver side. Figured that at 120k miles do both while at it. Happens that on one side the T-tab locking adjuster was broken. So in order to replace that he had to tear down the diff to get that into place. Anyways, that was done. We also went ahead and replaced front driver side wheel hub and both left and right tie rod ends.
No there is a problem. Drove the truck to work this morning as I was going to drop off at alignment shop and I noticed a heavy burning smell from the front driver side wheel and also the rim was extremely hot. All other rims were nice and cool and no funky smell. Is this possibly a bad new wheel bearing or am I now having brake issues?
By the way, the clunk noise is GONE!!!!
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yes, may be a bad new bearing assembly, yes, may be an assembly problem, yes, may have problem at brakes on that side, yes, brake line/hose could be holding pressure when foot is off brake pedal, yes, besides the smell, what did you experience?
C
crownvic31
Brake caliper bracket pin was seized. The passenger side was also alittle hard. Replaced both brackets with new hose aswell. Problem resolved. Now alignment tomorrow
Not a great pic but all i have for now
C
crownvic31
Ok, alignment is done. Escalade is running and feeling great. Just need to take car of little trimming in the bottom corner of the front bumpers as tire is running just slightly.
For anyone run running 35x12.50r24, what tire pressure are you guys running? The alignment place put 58PSI of pressure and I think that's way to much. Ride is a little hard. Should I just drop it 35PSI?
What is the recommended tire pressure on the sidewall at what weight rating? If you run the tire too low on air pressure, you will wear the outer edges of the tire too quick because the center of the tire will cup away from the road while rolling.
C
crownvic31
2835 max load at 65psi cold
load range E rating
Ply rating 10
If you are not towing and are not loaded up inside and just normal driving, I would run 55 psi. I like to drive hard and like the firmer grip and if mine I would run the 58-60 psi but 55 psi should be ok for you. I take curves at a faster speed and like my sidewalls less flexy.
C
crownvic31
Not towing. Daily driver to work by my self. I will drive it some more and see how I feel at 58.
Now I am guessing i need to recalibrate the tire sensors for the psi?
C
crownvic31
Washed her today and got some pics.
brice715
