Suspension help.
DaDenaliDude
Hello everyone, I have a question to ask. I’m going to be replacing my rear air shocks on my 2007 Denali with regular shocks. My question is do I also have to replace the spring or can I just use the same one that’s already on the truck. Also if anyone knows where I can find the module or resistors that keep the suspension warning light from coming on I’d appreciate the help. Thanks in advance.
The Denali springs are softer than the springs used on non-air rear shocks, as the air lift helps support the springs, while maintaining a soft/smooth ride.
You can replace the springs with Suburban springs of the same year (maybe other years, as well), or you can go with a coil-over rear shock (load leveler).
DaDenaliDude
DaDenaliDude
Thanks for the advice. I’m looking online at options now. Do you know anything about the resistors ?
If you go from an active shock system to as passive shock system, you need to install resistors across the 2 wires that go to each shock, so that your dashboard does not light up with 'Service Suspension' warnings. You can buy those anywhere, including Amazon.
If you go from an active shock system to a passive shock system using Arnott brand shocks, they have already built resistors into the shocks, so no external resistors are required.
DaDenaliDude
DaDenaliDude
Thanks for your help. I really appreciate it.
DaDenaliDude
DaDenaliDude
Moog 81069 for the HD rear springs that we use with regular shocks.
Why downgrade?
Both bladders are shot and I’m almost certain that the compressor is also and I don’t want to shell out over 1k just to fix it. I’m considering getting the Strustmasters kit that will convert the entire suspension for $750. It comes with the front and rear shocks and also with a module that’ll hide any error codes or lights on the dash.
DaDenaliDude
DaDenaliDude
I hear ya but that's the price for an exceptional ride that you're giving up.
True, I’m still debating what I should do though. I’ve heard good things about the kit I’m looking at. They say it’s a good ride. Obviously not like the Z55 but it’s decent. Plus my trucks old. She’s got 215k.
B-train
Arnott shocks have a lifetime warranty as well. I used them on my old 2007 and they worked great - 70k worth of miles on them before I sold it. My only suggestion is if you plan keeping the setup to go with a GM compressor. I've used both and had the aftermarket one fail way before it should. I think the OEM one has better components and corrosion protection.
DaDenaliDude
DaDenaliDude
Yeah I’m either going to go with Strutmaster or Arnott if I do decide to do the air delete.
DaDenaliDude
DaDenaliDude
Question, if I buy this kit could I reuse the front springs and transfer them over to this kit or would I have to purchase new springs?
You can reuse the front springs, but they will have 200k+ miles on them and they do weaken a bit over time. Youcould still use them, or buy new OEM springs for about $65 each.
DaDenaliDude
DaDenaliDude
Should I get Denali springs or a more heavy duty kind such as like some for a Z71?
If you liked the smooth Denali ride, then, I'd go with the Denali springs. A heavier spring in the front will do nothing positive, and will make the ride stiffer.
DaDenaliDude
DaDenaliDude
Your right. That makes sense. You know after researching all of this I am now thinking that if I’m about to shell out 800 on new suspension components I could just lower it instead. There’s a Belltech kit for 600 to do a 2-4 drop. In the end the suspension gets updated and I’ll get the subtle drop I’ve wanted.
DaDenaliDude
DaDenaliDude
This is the kit I’m referring to. A guy on YouTube has a video of him installing it on a 08 Denali I believe. Except he kept the air ride but I’m not worried about that.
Jrschultz
I have a 2010 Tahoe LTZ and it has road rough since day one. Bought it with 168k and it now has 250k. The suspension is horrible. Feels like it jumps all over when hitting bumps, and not really big bumps either! Any advice on what to change to make my ride a little more tolerable?
B-train
I have a 2010 Tahoe and it has road rough since day one. Bought it with 168k and it now has 250k. The suspension is horrible. Feels like it jumps all over when hitting bumps, and not really big bumps either! Any advice on what to change to make my ride a little more tolerable?
If your struts are original, I'd start there. I have a 2008 Denali and I replaced the original struts at 165K with plain 2019 Tahoe struts from an auto recycler. They had 40k on them and were $375 shipped.
The ride improved for sure. However, I've found that I still get some of the bouncy vibrations depending on how crappy the road is. It is overall better though. Tire pressure can play into that was well. There's a fine line between mpg pressure and pleasant ride pressure
isp5190
Our 2009 LTZ rides like a dream with 158,000 miles. I would check the front sway bar links. Awhile back ours was handling funny, checked and one sway bar link was gone and the other had worn out bushings. If the front struts and rear shocks have not been replaced with that mileage they are due for replacement. We bought ours as a CPO with 52000 miles, all shocks were brand new. I have had to replaced the rear air shocks at around 130,000
briannorris
