Mud Guards - WeatherTech or Husky?
Jura6ix
Hi everyone. Couple of questions:
1. Aside from those with power retractable steps, what is the downside of the GM splash guards?
2. I'll be picking up a 2022 Yukon SLT with the stationary steps; are front spash guards still recommended? I would presume they are, however, my salesman made a point to mention this to me.
Thank you,
R32driver
Thank you,
We have a '21 slt with fixed running boards and I can tell you without the splash guards this rig is ALWAYS dirty. The tires kick up everything from the road (or in my case a gravel driveway) and it shoots all over the side of the truck and covers the running board. I recently bought weathertech guards but haven't found an extra 10 minutes to put them on yet...
Stbentoak
Every vehicle I own has Flaps PERIOD. Saves the sides of the vehicles so much from rocks and tar and everything basically. Unless it is a sunshine weekend vehicle, get appropriate flaps on ASAP!
Jura6ix
Thank you, R32driver! This is helpful. May I ask why you went with Weathertech guards over GM?
WalleyeMikeIII
Sunny and Snowy Minnesota
I've got the weathertechs, love them, was really the only option for the power running boards...but they really keep the shmutz off the side and the boards, which keeps it out of the vehicle...Here in MN, kind of a must, or you end up w/ snow/ice all over everything in the winter.
R32driver
Mostly because I didn’t want the gmc logo on the rear guards. I’ve had most the badges removed from our Yukon so to keep with that theme just wanted them plain.
As a bonus weathertech products are made in the USA where as many gm items sadly are not
R32driver
Installed my weathertechs yesterday and it did not go as planned. I'm not sure what the deal is but the holes on the rears were not in the correct spot to easily be screwed on. I thought I was crazy at first but ended up having to drill out the middle holes into kind of an oval shape in order to get all 3 screws installed. I'd be pissed if it wasn't an easy "fix" but still annoyed as I spent probably 45 minutes screwing around with them when this should have taken a fraction of that time. They look great installed and fit the bumper contour very well.
The fronts took literally 5 minutes to install both sides. It's raining today so will get to see the difference after coming down my driveway that makes all vehicles filthy.
Stbentoak
This is one thing that weathertech has that is really worth it. They work great with my power boards. Mine assembled correctly and easily….
NIevo
Lewiston, ID
View attachment 369320View attachment 369322View attachment 369323
Funny you say that because I had the exact same problem in the rear with my Husky flaps. They work great and I think look better then the Weather Tech but the rear holes were a pain.
PaulGA
Luckily my weathertech's lined up, cause I'm terrible at improvising and I'm not at all mechanically skilled. The fronts gave me the most "trouble" just with torquing the furthest bolts trying to get around the tires (even with the wheel turned) but overall took me an hour or less. After a few drives I snugged the bolts and screws again just to make sure they stood tight and so far so good after a few weeks.
WalleyeMikeIII
My weather techs were a little difficult to install on the rears, but was fairly easy to resolve..the threaded clips under the rear bumper in the back just needed a small reposition and that solved it.
R32driver
These have made a world of difference stopping the mud and crap the tires were shooting all over the side of our ride. They’re not stopping 100% of it but doing a really good job. Should have got these on day 1
Stbentoak
WT are working great for me and work with power boards. Thats all I need to know....
Blackcar
My son put Husky in his Yukon I installed Weather Tech in my Yukon he likes his Husky and I like them better than Weather Teck I installed they curl up at rear doors and hard to keep looking nice.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Lots of threads here about the Weather Tech "CURL". I contacted Weather Tech via email and did receive a response that did not even address my CURL concern and just stated some crap about striving for quality. I wanted to throat punch the response.
Blackcar
Same here called them on driver side round button that snaps in carpet pin leaks and carpet gets wet in winter response was they do that. NOT! will not invest in weather tech again.
navyseal334
Just to be sure, you're getting curling on your Weather Tech mud flaps?
I've heard about the curl on the floor mats but not the mud flaps...
WalleyeMikeIII
WT's been on since Feb, work great w/ the power running boards, and are doing a bang up job of keeping the rockers clean...no complaints, and they look really good, color matches the black/graphite color of the lower trim moldings on the bumper and running boards! Glad I made this call..
BadDaddy2003
