Door Hinge Pins and Bushings???
GMT800 2005 Tahoe Z71
Navy Supporting Member
If all 3 trucks take same kit, then go for it but likely need kits specific to each year, make and model. Also, door support is important for success and check ALL hinge mount spots for weld or crack problems. Also, make sure the bushing mount holes are not wallowed out.
E
Eman85
3 trucks, 98 K2500, 97 Tahoe and 99 Yukon. I believe all use the same kit, I'll check before ordering and I'll only order 1 kit.
E
Eman85
Here's an update, I bought the GM kit that I linked. Save your money and just buy a good set of pins and bushings. Kit works but it's poorly engineered. The bushings are nice and press right in. The pins are stainless and screw together in the middle. They are hard to screw together and the grease fitting deal doesn't work well. When you pump grease in it's supposed to flow through the pin to the bushings. It flows through the pin but comes out at the bushing with the least pressure on it. Obviously not the bushing that is going to wear the fastest and need the grease the most.
E
Eman85
I'd have to figure out how to post pics, do you have to host them to get them on here? If you go to the Amazon link there's a review with pics.
It's pretty easy really. When you are typing a post, at the top of that window, to the left of the smilie face, there is a pic frame that you just tap on and follow the prompts. Hell, I am a BOOMER and I figured it out.
E
Eman85
Here's the pics, this site is easy many sites you have to host to photobucket or another site and then download from there. I'm a retired boomer too.
Looks like the kit comes from the UK or around there. They spell "center" with the e at the end "centere".
YukonGTmaster
2 Door w/ Barn Doors Club
That’s how we spell it up here in Canada too. Center=Centre. Color=Colour too. Haha!
E
Eman85
Here's the complete follow up. After doing my 98 K2500 I did the 97 Tahoe and used the infamous Dorman hinge pin kits and roller. The bushings are a sintered bronze and very brittle. I pressed the bushings in sing a bolt, washers, spacer and a nut. Bushings fit good and pressed right in. Roller assembly was bent so I removed it by cutting the top with a chisel and grinding it then driving it out with a long punch. Dorman roller had to have the knurling ground a little to be able to be driven in. Lower bushings broke the first day so I had to pull the pin and replace them, as I said they were brittle and they actually cracked.
Last but not least I did my 99 Yukon. On this one the roller was good so I tried one of the kits from Amazon that was a no name China kit. These kits have bushings that are metallic, will stick to a magnet. Pins fit a little looser in the bushings then I'd like. Bushings fit looser in the hinges and pressed in easy. When done there was a little bit of play felt when lifting the door that the others didn't have.
My take away on all of this..Best quality was the GM kit I put on my K2500 hands down. Dorman lives up to it's reputation of selling junk that you can make work but most likely won't last. The cheapo China kits are low quality but I'd say the bushings will last as they are steel or iron based. If I have to do the Tahoe or Yukon again I think I'll buy GM bushings and reuse the factory pins.
east302
Mississippi
The GM roller pins (12540326) are still available and don’t require the grinding like the Dorman ones.
But, you’ll need a weld stitch on the top or somehow peen it like the factory to keep it from working its way down.
E
Eman85
Just a follow up.. Pickup with the high dollar GM kit works like butter smooth as silk and gets greased when I service the truck, I'd recommend the kit.
97 Tahoe is in the shop today for.....hinge pin bushings. One year later and the bushings just fell apart, cheap Dorman junk. Daughter drives it and she's visiting for Christmas so I put a set of bushings I had and will order some of the Cunningham ones and do it one more time.
Can't follow up on the Yukon as I sold it.
YukonGTmaster
Do you have a part number for the good kit? My passenger door is sagging bad.
BadDaddy2003
