Drivers front door doesn’t always unlock
Landonz
I’ve been having issues with my drivers front door. It has a mind of its on and only unlocks half the time using the key fob. Has anyone experienced anything like this or know how to fix? Thank you!
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Sounds like the actuator is going out.
Shackman7878
San Bernardino
I had the same issue turned out to be the lock door trim was catching on the inside you can pop it off and see if that fixes your issue.
L
Landonz
Unfortunately I’m thinking its the actuator. Took that trim piece off, still doesn’t do anything. Only way it will unlock or lock is if i pull it up or push down manually
jatkinson8755
soundsl ike a faulty door lock actuator motor. theres a ton of info on it here --
L
Landonz
Awesome! Thank you! I received a new actuator in the mail today. Looks pretty simple with step by step directions.
Mohq
