2009 Chevy Tahoe Driver's window switch problems
Tahoe_SSV
Northern New Hampshire
So, my Driver's window switch isn't working properly. It will roll down the 2 rear windows, but the 2 front windows...Nothing. The passenger switch works fine and if I put passenger switch on drivers side it will roll window down. I took switch apart and cleaned the switch housing, the pad, plungers and all the contacts. That didn't work. Any ideas?
Geotrash
Dave
Richmond, VA
+1 to what @intheburbs said. Super easy to replace but you'll need a Tech 2 to program the new one to your truck.
LordWayback
Isopropyl alcohol if that doesn’t work new switch/wire pigtail my pigtail in my passenger side is giving me issues in my 01. etc etc
89Suburban
Bull in the china shop
SE PA
He can also roll the dice and try to find a used switch from a a similarly equipped truck and it could plug and play without the programming. I was able to do this finding one on eBay.
Tahoe_SSV
Tahoe_SSV
My drivers side switch will operate all windows accept for driver window. If I put passengers switch on drivers side it will work. Do I have to replace the whole unit? They are ridiculously expensive. At least 100 bucks.
89Suburban
SE PA
Are you sure it's not the regulator?
Pepper1700
